1996 Chevy Van engine starting
GCRIDER99
  • 1996 CHEVROLET VAN
1996 Chevy Van V8 Two Wheel Drive Automatic 137k miles
In the morning, my van turns over but won't start unless I spray a little ether in it. For the rest of the day it starts fine and runs great. I tried adding fuel injector cleaner but it didn't help
Thanks
Do you
have the same problem?
Friday, September 4th, 2009 AT 8:17 AM
MMPRINCE4000
  • EXPERT
Assuming you are not getting any error codes, it is a fuel problem.
Best approach is to have the fuel pressure tested with a mechanical gauge.
If OK, then I would suspect the cold start valve. It is a small injector that adds additional fuel on cold engines, it only operates when cranking and if not working will cause the no start (cold) you describe.
Friday, September 4th, 2009 AT 8:23 AM
Recommended Guides
