2003 Chevy Trailblazer
NICK GOMEZ
  • 2003 CHEVROLET TRAILBLAZER
how do you replace headlights?
Do you
have the same problem?
Monday, March 8th, 2010 AT 7:46 PM
HEADLAMP REPLACEMENT
REMOVAL PROCEDURE
1.Open and support the hood.
2.Remove the grille.
http://www.2carpros.com/forum/automotive_pictures/12900_hl_1.gif
3.Pull up on the retaining tabs (1) in order to remove the headlamp assembly from the headlamp panel.
4.Disconnect the headlamp leveling electrical connector from the motor/actuator if equipped.
5.Disconnect the headlamp electrical connector (2) from the headlamp assembly.
6.Remove the side marker socket (4) from the headlamp assembly.
7.Remove the park/turn socket (3) from the headlamp assembly.
8.Remove the headlamp assembly from the headlamp panel.
INSTALLATION PROCEDURE
1.Position the headlamp assembly to the headlamp panel.
2.Index and seat the tabs on the park/turn socket (3) to the headlamp assembly.
3.Index and seat the tabs on the side marker socket (4) to the headlamp assembly.
4.Connect the headlamp electrical connector (2).
5.Connect the headlamp leveling electrical connector to the motor/actuator if equipped.
6.Align and install the 4 locator pins on the back of the headlamp assembly into the retaining tab holes.
7.Push down on the retaining tabs (1) in order to lock the headlamp assembly into the headlamp panel.
8.Install the grille.
9.Close the hood.
Monday, March 8th, 2010 AT 9:34 PM
Recommended Guides
