Starter replacement instructions please? - How to remote start?
KERIBASKIN
  • 2007 CHEVROLET TAHOE
  • V8
  • 4WD
  • 36,000 MILES
I just bought a 2007 chevy tahoe ltz. It comes standard with the remote start feature. It has the remote start button on the keychain. When I hold it down (after I unlock the car) nothing happens. It will not start the truck.?
Friday, January 1st, 2010 AT 8:18 PM
If the remote start will not function then more then likely you have a door switch or hood switch that has failed and so the PCM thinks it is still open and it will not allow the remote start to function. So let's start with checking for codes using this guide:
However, if this all checks out, does the vehicle start properly using the key in the ignition switch?
We may have an issue with the starter so here is a couple guides on this:
https://www.2carpros.com/articles/how-a-starter-and-solenoid-works
I attached the process below on how to replace the starter if this proves out to be the issue. Thanks
Saturday, February 6th, 2021 AT 7:25 AM
TCHONEY
  • 2003 CHEVROLET TAHOE
  • V8
  • 4WD
  • 100,000 MILES
Trying to remove the starter on 2003 tahoe. It will not pull out due to what looks like a small bracket bolted to the oil pan/bell housing. Can't ge tto the two side bolts on the bracket to remove. What is the proper way around this?
Monday, June 28th, 2021 AT 7:05 PM (Merged)
BLUELIGHTNIN6
  • 16,542 POSTS
Here are the proper replacement procedures..
https://www.2carpros.com/forum/automotive_pictures/261618_Noname_657.jpg
https://www.2carpros.com/forum/automotive_pictures/261618_Noname2_167.jpg
