1998 Chevy Suburban
TRENTKOOP72
  • 1998 CHEVROLET SUBURBAN
  • V8
  • 4WD
  • 158,000 MILES
Delayed start/occational misfire/rough idle. Code1345a/changed crank and cam sensors/no change
Do you
have the same problem?
Thursday, July 30th, 2009 AT 12:08 PM
DOCFIXIT
  • EXPERT
1345 sets when cam crank sensors don't corrolate to distributor. Generally results from Dist. Not installed correctly. Like on tooth offf is all it takes. Has Dist been out to your knowledgf?
Thursday, July 30th, 2009 AT 12:33 PM
JDL
  • EXPERT
Hello, the cam and crank sensor maybe out of sync? You might also check the camshaft retard offset adjustment, hvs dist, v8. I don't know that you can correctly set that adjustment without a scanner?
Thursday, July 30th, 2009 AT 12:52 PM
Recommended Guides
