Parking Brake release broke
ONLY CHEVY
  • CHEVROLET SILVERADO
I have a 2002 Chevy Sliverado, V8 4.8l engine. I engaged the parking brake at work and when I went to release it, the cable broke but the brake is still engaged. Is there anyway to dis-engage the brake.
Thanks
Do you
have the same problem?
Friday, October 12th, 2007 AT 10:19 AM
MERLIN2021
  • EXPERT
Which cable broke? Front, middle, or a rear? Drum or disc brakes?
Friday, October 12th, 2007 AT 12:49 PM
ONLY CHEVY
It is the release cable inside that cab that you pull to release the brake. It is disc all the way around.
Friday, October 12th, 2007 AT 12:59 PM
MERLIN2021
  • EXPERT
On the same release lever there should be a small arm that points to the firewall, push it down and it will release, or if not get a screw driver and pull in the spot the cable attached to!
Friday, October 12th, 2007 AT 2:45 PM
ONLY CHEVY
That worked. Thanks
Friday, October 12th, 2007 AT 3:21 PM
