Parking brake cable
AALANO
  • CHEVROLET SILVERADO
How do you get PB cable off brake shoe
Do you
have the same problem?
Sunday, September 9th, 2007 AT 12:43 PM
M_H_RITZEL
  • EXPERT
You did not say what year the vehicle is. Guessing that you are having trouble removing the emergency brake from the shoe. Most common is a pin that goes through the secondary shoe, it is held on with a clip, to remove you have to pry the clip open so the pin will come out, then you can change shoes.
Sunday, September 9th, 2007 AT 4:57 PM
Recommended Guides
