HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Chevrolet
Silverado
Engine
1974 Chevy Silverado timing
JCPMYER
MEMBER
1974 CHEVROLET SILVERADO
Engine problem
1974 Chevy Silverado Engine Size unknown Two Wheel Drive Automatic 150000 miles
I need to know the timing setting on my 1974 chevy silverado 350
Sunday, January 20th, 2008 AT 2:32 PM
DENNYP
MECHANIC
8 degrees before TDC
Monday, January 21st, 2008 AT 10:35 PM
Please
login
or
register
to post a reply.
Related Engine Content
2007 Chevy Silverado Information On 8.1 Litre Engine
2007 Chevy Silverado V8 Four Wheel Drive Automatic Can You Tell Me Anything About The 8.1 Litre Gas Engine Used In The 2007 Chev...
Asked by
Brian Bullen
1 ANSWER
2007
CHEVROLET SILVERADO
VIDEO
Chevrolet Small Block V8 350 5.7L 390HP
Instructional repair video
GUIDE
Code Reading
A check engine light, also known as a service engine light, or a MIL (malfunction indicator light) is designed to let you know there is a problem with one of your car's...
Engine Heat
The Engine Will Not Get Above 135 Degrees. I Have Replaced The Thermostat, The Temperature Sensor. The Radiator Hose On Return Side Is Hot...
Asked by
Edward Gonzalez
1 ANSWER
1 IMAGE
1998
CHEVROLET SILVERADO
2006 Chevy Silverado Check Engine Light-fuel System
I Keep Getting A Check Engine Light. I Had A Mechanic Run The Codes And He Got Two Both Having To Do With The Fuel System. I Replaced The...
Asked by
dci520
2006
CHEVROLET SILVERADO
1994 Chevy Silverado Engine Information
Engine Mechanical Problem 1994 Chevy Silverado V8 Four Wheel Drive I Just Purchased A The Truck And Wanted To Put A New Engine In It...
Asked by
javi0sh
1994
CHEVROLET SILVERADO
2000 Chevy Silverado Engine Ideling To Fast
The Engine Is Idling To Fast And When I Put It In Park It Idles A Whole Lot Faster And Just Runs A Little Fast When It Is In Gear
Asked by
TJ FERGUSON
1 ANSWER
2000
CHEVROLET SILVERADO
VIEW MORE
Fuel Economy
Turn Over an Engine by Hand | Bar Over
