Transmission removal
MBEBBER
  • 1998 CHEVROLET S-10
  • 4 CYL
  • MANUAL
How do I remove the transmission and hydraulic line from the clutch slave cylinder?
Wednesday, December 1st, 2010 AT 7:11 PM
DOCFIXIT
  • 18,828 POSTS
Here is a video of the job being done on a similar car. The process is the same.
https://youtu.be/JpzefqEeVGE
This guide can help as well
https://www.2carpros.com/articles/throw-out-bearing-replacement
Wednesday, December 1st, 2010 AT 7:54 PM
AMANDASR98
  • CHEVROLET S-10
How do you remove an automatic transmission from a 1998 chevy s10 zr2? This truck has 117,000 miles on it, and it has a 4.3 motor. My husband has started taking the transmission out, but has hit a stumbeling block. He can't get it to actually come out.
Wednesday, January 16th, 2019 AT 6:26 PM (Merged)
WOOHOG1
Well first do you have a haynes or Chiltons manuel? If he has that it should provide much of the information in there. What sort of stumbling block has he run into?
AMANDASR98
Yes, he has that manual. He was able to get it out last night. Thank you for the reply though.
PHILIP37
  • 1997 CHEVROLET S-10
  • 4 CYL
  • MANUAL
  • 168,000 MILES
I am trying to remove and replace the slave cylinder for my hydraulic clutch, so far I have taken off all of the bolts holding the bell housing to the engine, and I still cant seem to get the transmission/bell housing to come free. I have tried using a pry bar to separate the two and have successfully achieved about 1/2" of space between the two but is still feels like there is something else needs to be removed.
Wednesday, January 16th, 2019 AT 6:27 PM (Merged)
JAZEYDEZEY
  • 18 POSTS
Did you take out the clutch fork. And is engine supported level with trans if they are both straight it should come apart let me know if you got it good luck
TISHO
  • 1995 CHEVROLET S-10
  • 160,000 MILES
The job - Changing the flywheel
We are doing it in our garage with transmission jack.
Trying to unscrew the transmission so we can lower it and change the flywheel. Removed all of the bolts except TWO in the front. We can't reach them.
  • 108,269 POSTS
If they are the two at the top of the bell housing, I always have used a box end wrench. There was never room for anything other.
PRESTON_THORNBURG
  • 1999 CHEVROLET S-10
Transmission problem
1999 Chevy S-10 Two Wheel Drive Manual
how do you replace the slave cylindar on a 1999 chevy s-10
BLUELIGHTNIN6
  • 16,542 POSTS
1. Remove the transmission.
2. Remove the 2 bolts securing the concentric slave cylinder to the transmission and input shaft.
3. Remove the concentric slave cylinder from the input shaft.
To install:
4. Install the concentric slave cylinder over the transmission input shaft making sure the bleed screw and coupling are properly positioned and install 2 bolts.
5. Tighten the bolts to 80 inch lbs. (9 Nm).
6. Install the transmission.
7. Bleed the clutch hydraulic system.
SIRCAM
  • 0.6L
  • 6 CYL
  • 120,000 MILES
I was changing my transmission strainer and in tbe process of taking off the pan I had to remove a brackett that supports the gear cable right about to the front of the pan is the actual gear that changes the gears. I did loosen the bolt and I heardnthe click so I moved the gear. I was successful in doing my strainer but I can not get these gears back right, did I unajust them, or do I Just by turning the cable? Please help rectify this situation.
HMAC300
  • 48,601 POSTS
You'll have to readjust the cable.
Ensure shift tube and lever are free in steering column. To adjust linkage, remove screw and spring washer from swivel. Turn transmission lever clockwise to stop, then counterclockwise 2 detents. This is Neutral position.
Place selector lever in Neutral. Locate proper position using mechanical stops, NOT shift indicator pointer. Hold swivel against shift lever. Install spring washer and screw. Tighten finger tight. Avoid applying force in either direction (along shift rod or lever) while tightening screw to specification
2CP-ARCHIVES
  • 4,540 POSTS
  • 1996 CHEVROLET S-10
  • 110,000 MILES
How do I remove manual transmission
KHLOW2008
  • 41,815 POSTS
Removal
1. Disconnect negative battery cable. Shift transmission into 3rd or 4th gear. Remove shift lever retainer screws and retainer. Remove 8 shift lever boot mounting screws and boot. Remove shift lever insulator. Remove shift lever. Remove 4 exposed bolts on base of housing, not bolts under rubber boot located at top of housing. Remove insulator from transmission case. Raise and support vehicle. Drain transmission fluid.
2. Mark drive shaft for reassembly reference. Remove drive shaft(s). On 4WD, remove transfer case shield. Drain oil from transfer case. Remove vent hose and electrical connectors. Remove transfer case shift linkage. Using a jack, support transfer case. Remove transfer case and discard transmission adapter gasket.
3. On vehicles equipped with drive shaft parking brake, release parking brake. Raise and support vehicle. Remove nut and washer from center of brake drum. Remove drum yoke assembly, bolts, washers and drum yoke. Remove cotter pin, clevis pin, clevis, and nut from brake cable. Remove parking brake cable grommet, and cable from bracket.
4. On all vehicles, disconnect exhaust pipes from exhaust manifold, and catalytic converter from muffler assembly (if necessary). Disconnect electrical connectors from speed sensor and back-up light switch. Using Quick Connect Disconnect Tool (J-36221), remove clutch line from concentric slave cylinder quick connect coupling. Remove starter and clutch housing cover. Remove transmission vent hose.
5. Support transmission and engine. Remove crossmember. Remove clutch plate and clutch cover from flywheel. Remove transmission-to-engine bolts and studs. Pull transmission straight back on clutch hub splines. Remove clutch and clutch cover plates during transmission-to-engine separation. Remove transmission.
ANDYMARY
1997 Chevy S-10 6 cyl Two Wheel Drive Automatic
I am trying to change the transmission in my 1997 Chevy s-10 4.3v6. I can't get clearance to unbolt the old transmission. Can you give me tips and instructions on how to do this and get the new one back in?
SWILLIAMS
  • 597 POSTS
Two ways. One is to remove the body bolts and jack the body up a bit in front. The second is to remove the trans cross member and then remove the engine mounts to drop the engine down. Then there is also the way I use. Long extensions and crows foot wrenches.
FREIGHT_TRAIN
  • 4 CYL
  • MANUAL
  • 180,000 MILES
I understabd how to change it from another post but how do I drop the tranny down any info tnx
BMRFIXIT
  • 19,053 POSTS
Disconnect negative battery cable. Shift transmission into 3rd or 4th gear. Remove shift lever knob and nut. Remove shift lever retainer screws and retainer (if equipped). Remove shift lever boot mounting screws and boot. Remove shift lever and nut.
Remove exposed bolts on base of housing. DO NOT remove bolts under rubber boot at top of housing. Remove shift lever housing. Raise and support vehicle. Drain transmission fluid. Remove parking brake cable for clearance. Mark drive shaft(s) for reassembly reference. Remove drive shaft(s).
Disconnect electrical connectors from speed sensor and back-up switch. On all models, disconnect exhaust pipe from exhaust manifold. Remove catalytic converter and hanger. If equipped, remove right and left side transfer case-to-transmission braces. On 4WD, place transfer case in 4H position. Remove skid plate. Drain fluid from transfer case. Disconnect vacuum lines and electrical connectors from transfer case (if equipped).
Disconnect shift cable from transfer case. Support transfer case with jack. Remove transfer case-to-transmission mounting bolts. Slide transfer case rearward until free of transmission output shaft. Lower and remove transfer case. Remove and discard gasket. Using Quick Connect Disconnect Tool (J-36221), remove clutch line from concentric slave cylinder quick connect coupling.
Remove clutch housing cover. Remove clutch plate and clutch cover from flywheel. Support transmission. Using a fuel pressure gauge, purge fuel system, and disconnect fuel lines. Remove fuel lines and retainers from rear crossmember. Remove rear crossmember. Move wiring harness away from transmission oil pan.
Lower transmission enough to gain access to top of transmission. Remove wiring harness from front crossmember. Remove engine block ground. Remove transmission mounting bolts as necessary. Pull transmission straight back on clutch hub splines, and remove transmission.
https://www.2carpros.com/forum/automotive_pictures/99387_Graphic2_174.jpg
FREIGHT_TRAIN
Very good info thx also if 1 were to take it to a garage what kind of time would be required for this type of repair? Im tryin to see if its worth it also its a 2.2l 2wd model.
BMRFIXIT
  • 19,053 POSTS
4 to 5 hours of labor
plus you have to add parts
good luck
