Signal flasher location?
WILLIAM CHAUVIN
  • 1996 CHEVROLET S-10
  • 4 CYL
  • 110,000 MILES
Where is the signal blinker flasher located?
Wednesday, February 10th, 2010 AT 1:21 PM
2CARPRO JACK
  • 11,533 POSTS
The flasher for the turn signals is in the power distribution center below the left side of the dash, round silver thing with 2 prongs on the plug. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
Wednesday, February 10th, 2010 AT 3:17 PM
WILLIAM CHAUVIN
  • 6 POSTS
Thanks for the info. --but --the flasher is not on left side of dash.It is in center os dash board under radio next to cigarette lighter --behind panel.
https://www.2carpros.com/forum/automotive_pictures/338857_1996_chevs10_blinkers_003_1.jpg
Thursday, February 11th, 2010 AT 1:25 PM
2CARPRO JACK
  • 11,533 POSTS
Just going off my software, was wondering if it was in that power center. Sorry about that. Did it fix the problem?
Thursday, February 11th, 2010 AT 3:30 PM
WILLIAM CHAUVIN
  • 6 POSTS
Yes Ken the signals are working fine now. After I droped the bottom panal I replaced both blinkers. The old ones were aluminum and replaced with new dark plastic cased ones.(Auto zone) as shown in photo.
Friday, February 12th, 2010 AT 2:16 PM
2 LINSEY
  • 287 POSTS
We appreciate your donation and look forward to helping you in the future. Thank you
Monday, March 1st, 2010 AT 4:20 PM
QUARESMAC
Electrical problem
1996 Chevy S-10 6 cyl Two Wheel Drive Automatic
I want to replace it myself. Where do I go /how do I replace. Is there a diagram to show where its located
Tuesday, October 1st, 2019 AT 6:11 PM (Merged)
MKGYS
I have a 97 S-10 and the flashers are located under the cig lighter/power ports. I had to take the lower dash apart to get to them. It was such a pain, I replaced both while I had it open.
1OF7
  • CHEVROLET S-10
I have a 1996 Chevy S10, LS, 4x4, 4.3L with 98000 miles. I know that I need to replace the flasher, but I can't find it. I feel that this should be easy to replace, but I am running out of places to look. HELP!
LODICHEVYBOY
  • 1995 CHEVROLET S-10
  • 4 CYL
  • MANUAL
  • 151,958 MILES
Were is the flasher for my turn signals located in my 1995 chevy s10?
Thanks
DAVE H
  • 13,383 POSTS
Hello .. thanks for the donation .. much appreciated
Hazard/Turn Signal Flasher (Analog Cluster)On convenience center.
Hazard/Turn Signal Flasher (Digital Cluster)On fuse block.
https://www.2carpros.com/forum/automotive_pictures/266999_s10_1.jpg
Hope this helps
https://www.2carpros.com/forum/automotive_pictures/266999_AAA2_1063.png
OLM
  • 269,448 MILES
Where is the brake flasher located on a 1995 chevy s-10 v-6
WRENCHTECH
  • 20,758 POSTS
I don't know what brake flasher you're looking for but the turn signal flasher is here.
https://www.2carpros.com/images/external/97134779.gif
The Turn Signal Flasher is located behind Knee Bolster, near Cigarette Lighter.
GAHAN
Electrical problem
Does anyone know definitively where the turn signal flasher switch is located on a 1996 Chevy S-10 Pickup? I have been told inside the steering column housing but I removed bottom plate and see nothing that looks like it up in there. Nobody at parts stores or even the Chevy dealerships I called are any help. Thank you for any help you can provide.
Tuesday, October 1st, 2019 AT 6:12 PM (Merged)
TURN SIGNAL LAMPS FLASHER
I/P Wiring (Center)
https://www.2carpros.com/forum/automotive_pictures/12900_tsf1_2.jpg
Power Distribution Center
https://www.2carpros.com/forum/automotive_pictures/12900_tsf2_2.jpg
The Turn Signal Lamps Flasher is located in the Power Distribution Center. The Power Distribution Center is located in the Instrument Panel below and in front of the Radio.
Turn Signal Switch
Inflatable Restraint Steering Wheel Inflator Module
https://www.2carpros.com/forum/automotive_pictures/12900_tssc1_1.jpg
Steering Column Assembly
https://www.2carpros.com/forum/automotive_pictures/12900_tssc2_1.jpg
WARNING: Refer to Air Bags and Seat Belts/ Air Bags (Supplemental Restraint Systems)/ Service and Repair/ Air Bag System Disarming & Arming.
1.Remove ignition lock.
2.Remove shift lever clevis, then the lever from vehicle.
3.Remove wire harness straps, then disconnect steering column bulkhead connector from vehicle wire harness.
4.Disconnect turn signal switch gray and black connectors from column bulkhead connector.
5.Remove pan head tapping screws, then the turn signal switch assembly from column.
6.Reverse procedure to install. Torque pan head tapping screws to 53 inch lbs.
