1994 Chevy S-10 Starter Removal
ARNIE99
  • 1994 CHEVROLET S-10
  • 4 CYL
  • 90,000 MILES
Have removed all mounting bolts and brackets from starter on 1994 chevy s-10. Starter is hanging loose but am unable to remove it from vehicle. Do I need to remove transmission bell housing (flywheel cover) to remove starter or is there another trick to this?
Do you
have the same problem?
Friday, October 16th, 2009 AT 1:42 PM
  • EXPERT
Nothing else needs removed. If you removed the mounting bolts, it should come out.
Saturday, October 17th, 2009 AT 4:14 PM
DALIXIN
I have a 1994 s-10 4x4, manual, and there was two ways I could get the starter out. Either remove the bell housing of the transmission or take the the solenoid off the starter.
With the solenoid on the starter the assembly could not come out between the frame and bell housing, but if you removed it there would be enough room to remove it.
Tuesday, October 12th, 2010 AT 3:13 PM
Recommended Guides
