HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Chevrolet
S-10
Engine
Starter
1994 Chevy S-10
HIDEOUS1
MEMBER
1994 CHEVROLET S-10
6 CYL
4WD
AUTOMATIC
214,000 MILES
The starter won't turn. I've checked the battery and starter and they're good. What should I check next?
Sunday, January 27th, 2008 AT 10:29 PM
MECHANIC
Get your helper to put key to start while you're underneath checking for power at the small terminal purple wire on the starter -do you have power?
Sunday, January 27th, 2008 AT 11:06 PM
Please
login
or
register
to post a reply.
Related Starter Content
Hi Someone Cut My Power Cord To My Starter. I Need To...
I Need To Know Where To Splice The Cord To On The Starter Without Having To Pull The Starter Out.
Asked by
Ryank44
2000
CHEVROLET S-10
GUIDE
Starter
An engine starter is constructed as a high torque, high amperage 12 volt motor fitted with an electrical solenoid and Bendix gear which is used to rotate an engine between...
1985 Chevy S-10 Starter
I Tried To Start My S-10 Blazer Today. It Started And The Starter Continuid Spinning, Making A Were Noise. I Turned Off The Ignition But It...
Asked by
blazer6161
1 ANSWER
1985
CHEVROLET S-10
Will Start If I Spray Starter Fluid
My Truck Will Start If I Spray Starter Fluid In It But Will Turn Off As Soon As The Truck Burns The Fluid, What Could Be Wrong And How...
Asked by
Chasetw1
1995
CHEVROLET S-10
Starter?
I Have A 1983 V6 S10 And I Jus Dropped A New Battery In It But It Doesnt Want To Turn Over What Could Be Wrong?
Asked by
Danielhanson
1983
CHEVROLET S-10
1987 Chevy S-10 Starter
Where And How Do I Fix My Starter
Asked by
SSonny
1 ANSWER
3 IMAGES
1987
CHEVROLET S-10
VIEW MORE
Starter Motor Replacement
Starter Replacement
