1999 Chevy Monte Carlo fuel fillter
BAI
  • 1999 CHEVROLET MONTE CARLO
  • 6 CYL
  • FWD
  • 175,000 MILES
Is my 1999 chevy monte carlo fuel sysem pressurized? I want to change my filter and it warned me to check my system before installing new one. If so how do I depressurize it, so it can be installed.
Do you
have the same problem?
Saturday, December 19th, 2009 AT 1:15 PM
BLUELIGHTNIN6
  • EXPERT
Disconnect the negative cable at the battery then loosen the fuel tank filler cap to relieve any fuel tank vapor pressure. Wrap a shop towel around the Schrader valve on the fuel rail and remove the dust cap from the valve. Connect the fuel pressure gauge to the Schrader valve. Install the free end of the gauge bleed hose into an approved gasoline container, and open the gauge bleed valve to relieve the fuel pressure.
Sunday, December 20th, 2009 AT 1:16 AM
Recommended Guides
