Cruise control not working
JOHN HO10
  • 2006 CHEVROLET IMPALA
  • 6 CYL
  • FWD
  • 95,000 MILES
Cruise control cuts in and out. After non-diagnosis by local shop, I checked the fuses and relays in fuse box under hood. I found several were not seated all the way. I pushed all down to seat properly and cruise worked fine for months. Now have problem again, and I re-seated relays and fuses. But problem resumes.
Unfortunately, Chevy fuse box and owners manual DOES not identify cruise fuse or relay. Help!
Monday, October 11th, 2010 AT 10:57 AM
MMPRINCE4000
  • 8,548 POSTS
Use an electronics cleaner and dielectric grease on fuses, this should solve problem.
Wednesday, October 13th, 2010 AT 9:17 AM
JOHN HO10
  • 46 POSTS
In addition to the above symptoms, the RPM's would increase 200-300 without a corresponding increase in speed. This condition occured in or out of "cruise" mode and frequently when car was cold. Cold weather seemed to make it worse. However, at times, after a warm up the cruise worked fine.
Frustrated, I took car to my shop. They discovered that the wire harness connected to the trans speed control sensor had corroded. They replaced wire harness and speed sensor. Works fine now.
Hope this helps those who were looking to replace the brake light switch. Perform electrical diagnostics on the trans speed sensor connector first.
Wednesday, February 9th, 2011 AT 6:23 PM
JAMES CONKWRIGHT
  • 2005 CHEVROLET IMPALA
  • 6 CYL
  • FWD
  • 30,000 MILES
Cruise control quit working and its not any fuses
Sunday, May 17th, 2020 AT 11:22 AM (Merged)
DE772601
  • 123 POSTS
Hello well first if its not any fuses than if your cruise control switch is on the colum on the left side, they call that a multi function switch which will go bad causing it not to work. You will have to take the colum apart to do this because the wires run down through to the bottom. I hope this will be of some kind of help to you.
DRAKEMAN62
  • 6 CYL
  • FWD
  • 89,950 MILES
Earlier this week, I was driving on the interstate, I touched the brake to take a ramp. When I hit the resume button the light for the cruise came on, but it did not hold the speed. I've checked the fuses (2 in the main box) and reset the computer. To no avil, it still doesn't work. Help! I drive for my job. Could it be the speed module?
2CARPRO JACK
  • 11,533 POSTS
Have it scanned for any codes the PCM amy have stored. Could be many different things lets see if it has codes first and get back to me.
DRAKEMAN62
I had the car scanned and no codes were recorded. My guess is something broke. But what do I look at first? Thanks for the help.
2CARPRO JACK
  • 11,533 POSTS
Check the brake light switch, it is also for the cruise and it might have stuck "open" so that the cruise thinks that you are on the brake
DRAKEMAN62
Well I've installed a new brakelight switch. However, the problem still exists. Could it be the switch on the steering wheel or something with the computer?
2CARPRO JACK
  • 11,533 POSTS
Could be either one, If all fuses are good then it sounds like some electrical diagnosis will need to be done. You have a meter and or test light?
WILLIAM BAILEY
Electrical problem
2005 Chevy Impala 6 cyl Front Wheel Drive Automatic
when I push the button to engage the cruise it wont set. What are the possible causes of this and what are the solutions
BLACKOP555
  • 10,371 POSTS
First thing to do is check the brake light switch and make sure the brake lights are working mainly the high rise one aka 3rd brake lights.
SADANIEL
  • 2003 CHEVROLET IMPALA
  • 6 CYL
  • FWD
  • 178,000 MILES
Hello, intermittently my cruise control will disengage as I am driving down the highway with it engaged. When this happens you feel the car gives a little jerk and the dash light goes out for the cruise control. Its seems once this happens it will not work until you turn off the car and try it on the next trip. Also, sometimes when I go to turn on the cruise control it will not engage (no light on the dash board).I would say that the cruise control works about 75% of the time for turn on but fails probably about 30% of the time while it is engaged.
Any ideas on what might be wrong?
Thanks,
Scott
RHALL77
  • 3,361 POSTS
You will need a scan tool to check for trouble codes. The cruise module is loosing a signal from somewhere. Could be a brake switch, set switch ect. A scan tool will show this when it happends
MLE_ABS
  • 2002 CHEVROLET IMPALA
  • 6 CYL
  • 102,000 MILES
Recently my cruise control light would come on on my dash lights, and the cruise would not work. It has stayed on for days at a time. I realized that at the same time that the cruise light was on (with the switch turned off) that my heater/AC system would not work at all. I could not change the air flow buttons, when turned on no air would come out, and even the light for the rear defrost would not work when pushed, the heating/AC system was completely out.
The strangest part; when the cruise light is off, the heater/AC works, when it is on the AC will not work, and then gone. I am assuming a connection in there.
Any suggestions as to what can be causing such a stir? I have had all of my fuses checked and they are all good. Also, I have recently put in a new battery in preparation for an Arizona summer.
Please advise!
LEGITIMATE007
  • 5,121 POSTS
This sounds like a BCM issue. I would try to get a sued one and plug it in to see what happens. Here is the location.
Cheers
MLE_ABS
I took my car into the dealership and they told me that the problem is my ignition switch. Has anyone heard of this before? I am confused how those would tie together! Please advise.
MINISTRYOS73
Did you ever get this problem fixed and what was the issue? I am having the same problem. Thank you.
MLE_ABS
I had the ignition switch replaced, and the A/C blower started working again. Still no cruise, but I can live with that.
JEH
I had this problem and the dealer replaced the BCM for $489.00 all fixed
