Where is the cabin air filter
CAD36
  • 2008 CHEVROLET IMPALA
  • 50,000 MILES
How do I change the cabin air filter
Wednesday, May 30th, 2012 AT 12:39 PM
KHLOW2008
  • 41,814 POSTS
Removal & Installation
1. Position the windshield wipers in the "up" position, by keying the ignition OFF when the wiper reach the desired position. Raise the hood.
2. Remove the rear hood seal from the pinchweld flange in the right rear corner. Remove the washer hose from the right air inlet grill panel and position aside.
3. Remove the two push pin retainers from the right air inlet grill panel. See Fig. 4.
IMPORTANT:
Do not remove the third push pin retainer from the right air inlet grill panel.
4. Position the left side of the right air inlet grill panel on to the windshield. Remove the passenger compartment air filter. See
Fig. 5. To install components, reverse removal procedure.
Wednesday, May 30th, 2012 AT 1:17 PM
RRTSCB
  • 2007 CHEVROLET IMPALA
  • V8
  • FWD
  • 38,558 MILES
Where is the Cabin Filter located on my car?
Friday, January 10th, 2020 AT 12:41 PM (Merged)
RRTSCB
Thank you very much but found it when I bought the new cabin filter; imagine that, it actually had good directions!
Take care all!
2CP-ARCHIVES
  • 4,540 POSTS
  • 2003 CHEVROLET IMPALA
  • 152,000 MILES
Where is the cabin air filter located on 2003 Chev Impala LS
HMAC300
  • 48,601 POSTS
If you have one it wil be like in picture, you may have to remove wipers and vent grille in front of windshield.
BAHEON
  • 5 POSTS
2003 Chevy Impala 6 cyl Front Wheel Drive Automatic
Is there a cabin filter in a 2003 Impala? If so, where is it?
LOUT5369
  • 217 POSTS
It should be on the right side of the cowl when you open the hood.
BAHEON
  • 5 POSTS
I know the engine air filter is there, I was asking about a cabin (inside the car) filter. Is it still on the right side in the engine compartment?
DOCFIXIT
  • 18,828 POSTS
Turn wipers on cut off ignition stoping blades in up position. Open hood remove hood rear seal half way from pass. Side to center. Remove the wiper arm and hose. Remove air inlet grill then remove filter
SCHIPPEE
  • 6 CYL
  • FWD
  • 86,000 MILES
I have bought a cabin filter for my car but can't locate where it is in the car. I just bought the car a week ago and no manual book came with it. Can you please let me know where I could locate it. Thanks
Tim
BMRFIXIT
  • 19,053 POSTS
With hood closed, turn on windshield wipers.
Stop windshield wipers in raised position.
Raise the hood.
Position aside the rear hood seal halfway to the center.
Noting the installed position for reassembly reference, remove the wiper arms.
Disconnect windshield wiper hose from air inlet grill
Remove air inlet grille retainers and grille on right side.
Remove passenger compartment air filter.
To install, reverse removal procedure.
https://www.2carpros.com/forum/automotive_pictures/99387_Graphic1_450.jpg
https://www.2carpros.com/forum/automotive_pictures/99387_Graphic2_224.jpg
https://www.2carpros.com/forum/automotive_pictures/99387_Graphic3_107.jpg
WCSUMNER
  • 2000 CHEVROLET IMPALA
  • 6 CYL
  • FWD
  • 138,000 MILES
Location of filter and if there is any special way to replace it
REMOVAL PROCEDURE
https://www.2carpros.com/forum/automotive_pictures/12900_a1_7.gif
Position the windshield wipers in the UP position, by keying the ignition OFF when the wiper reach the desired position.
Raise the hood.
Position aside the rear hood seal halfway to the center. Refer to Seal Replacement - Hood Rear in Body Front End.
Remove the right air inlet grill.
INSTALLATION PROCEDURE
https://www.2carpros.com/forum/automotive_pictures/12900_a2_5.gif
Install the passenger compartment air filter.
Install the air inlet grill. Refer to Air Inlet Grille Panel Replacement in Body Front End.
Install the rear hood seal.
Close the hood.
Return the windshield wipers to the PARK position.
TKRUSE03
  • V6
  • RWD
I want to replace the cabin filter. The air conditioner ticks sometimes when the blower is running down to stop.
Is it easy to replace the filter on Impala?
WRENCHTECH
  • 20,758 POSTS
The filter is not hard to change but I assure you it is not causing your noise.
Removal Procedure
Open the hood.
Remove the 2 push pin retainers from the right air inlet grill panel.
Important: Do not remove the third push pin retainer from the right air inlet grill panel.
Remove the water deflector cover.
https://www.2carpros.com/images/external/117234586.jpg.gif
CWILLIAMS27801
Where and how do I change the cabin air filter?
Monday, January 4th, 2021 AT 8:54 AM (Merged)
HMAC300
  • 48,601 POSTS
https://www.2carpros.com/forum/automotive_pictures/406719_cabin_filter_3.jpg
hope this comes through right........
ASEL
  • 2002 CHEVROLET IMPALA
  • 6 CYL
  • 10,200 MILES
Where and exactly how do I replace the in cabin air filters. Step by step please.
Also, exactly, step by step, how do I take out engine fan assembly?
BLUELIGHTNIN6
  • 16,542 POSTS
With hood closed, turn on windshield wipers. Stop wipers in raised position
raise the hood, position aside the rear hood seal halfway to the center
noting the installed position for reassembly reference, remove the wiper hose from air inlet grill
remove air inlet grille retainers and grille on right side
remove passenger compartment air filter
reverse procedures to install
