My info shows the filter is located on the rear crossmember, underneath, you need to look.
The filter shows to have a threaded fitting on one end and a quick connect fitting on the other end. I have used needle nose pliers on that type fitting. It's probably best to use the proper tool. I believe the autostores sell them.
Make sure there is no pressure on the system, before you take anything loose.
Friday, February 8th, 2019 AT 6:28 PM
(Merged)
