Firing order?
STEPHENR1128
  • 2000 CHEVROLET BLAZER
I need the spark plug wiring diagram for this vehicle. Having trouble with misfire after installing new wires. Need to make sure wires are put back correctly.
Friday, February 20th, 2009 AT 11:14 AM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 42,895 POSTS
Hello, my information showed this for the 2000-4.3-vin X and K.
Firing Order 1-6-5-4-3-2
https://www.2carpros.com/forum/automotive_pictures/170934_chevy_blazer_1.jpg
Cheers, Ken
Wednesday, September 20th, 2017 AT 4:24 PM
CHRISTEIXEIRA
  • 1999 CHEVROLET BLAZER
Whats the Firing Order on 1999 Chevy Blazer 4.3l engine
Friday, May 14th, 2021 AT 12:34 PM (Merged)
KEN L
  • 42,895 POSTS
Here is the firing order for your car 4.3 v6 engine. (Below)
Cheers, Ken
KEITHPRIVETT
  • 1998 CHEVROLET BLAZER
Spark plug wire diagram?
JDL
  • 16,098 POSTS
https://www.2carpros.com/forum/automotive_pictures/170934_firing_order_1.jpg
The info showed this for the 4.3.
MWILDER75
  • 1994 CHEVROLET BLAZER
  • 6 CYL
  • 4WD
  • 1,470,000 MILES
What is the number 1 position on distributer cap?
At 5 O clock position-see below
WRENCHTECH
  • 20,757 POSTS
This picture might be easier to read.
MWILDER75
Thank You for your help this worked
IAMGRAYSONC
  • 99,950 MILES
I changed spark plug cables and distributor cap and think I have them installed in the wrong order?
HMAC300
  • 48,601 POSTS
Here is the ignition system firing order for your truck 1-8-4-3-6-5-7-2 pic included. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
DANNY L
  • 5,648 POSTS
Glad to hear this information helped. Thanks for using 2CarPros and we hope you will use our site again in the future when needed.
Danny-
BRYANTD
What's the firing order for a 1992 chevy s10 blazer 4.3
KEN L
  • 42,895 POSTS
Firing Order. 1-6-5-4-3-2 . Please let us know if you need anything else to get the problem fixed.
EDWARD BECCO
I need to see a diagram on how to put the wires in order
Friday, May 14th, 2021 AT 12:35 PM (Merged)
https://www.2carpros.com/forum/automotive_pictures/12900_fo_95.jpg
REDLOVER8
  • 1993 CHEVROLET BLAZER
My father passed away a few years ago and left his jeep in the garage. It doesnt run. It turns over but wont start. I am getting fuel and air so my next area to look is spark. He put a 4.3L from a '93 chevy blazer into it. It has a tbi but I dont know if that came with the engine or not. I have searched the internet and found some websites for other year engines. But I would like to know for that specific year where the spark plug wires go. Basically what terminal on the distributor attaches to what spark plug. Thank you for your time. Josh.
JDL
  • 16,098 POSTS
https://www.2carpros.com/forum/automotive_pictures/170934_chevy_blazer_2.jpg
Hello, I came across the above picture. I'm not sure I trust pictures? You can put the number one cylinder on tdc of compression stroke, then whichever coil tower the rotor is pointing at or leading into, is the number 1 tower, you can see the firing order and direction of rotation on the cap. Did this vehicle run after the engine change-over?
BRYANTD
  • 1992 CHEVROLET BLAZER
  • 4.3L
  • V6
  • 226,222 MILES
Just did a tune up and can't remember the firing order on my vehicle. Any help would be much appreciated.
  • 108,192 POSTS
Welcome to 2CarPros.
Not a problem. Here is the firing order:
IGNITION FIRING ORDER
The attached picture shows cylinder location.
Picture 2 shows wire routing and if you look at the distributor, it indicates which wire goes to each cylinder.
