Heated seats
RIBSPLITTER2007
  • 2007 CADILLAC ESCALADE
Front heated seats in a 2007 cadillac escalade not working, how do repair?
Tuesday, January 18th, 2011 AT 9:52 PM
FACTORYJACK
  • 4,159 POSTS
First thing to check is connections/fuse (driver seat 2). If this has heated/cooled seats, check the larger connector at the seat climate module under the front of the passenger seat. Usually the ground(large black) or power(rd/wht) shows signs of heat damage and poor connection. Here are the heated seat wiring diagrams so you can see how the system works if the fuses and connection are good 9 times out of 10 its the seat control module. Here and instruction on how to change and program the module.
Check out the diagrams (Below). Please let us know what you find. We are interested to see what it is.
Cheers
Saturday, January 22nd, 2011 AT 7:15 AM
SRLAWSON
Thank you for this post it was the seat module on my car cost me $130.00 to have the module programmed all fixed! I love this site.
Friday, November 9th, 2018 AT 1:17 PM
POL98XC6
  • 2000 CADILLAC ESCALADE
  • V8
  • 4WD
  • 111,000 MILES
Heated seats won't work. I checked for voltage at the fuse and I have none. Wonder what could be causing that?
Friday, November 9th, 2018 AT 1:18 PM (Merged)
BLUELIGHTNIN6
  • 16,542 POSTS
Disconnect Black 2-pin seat belt switch connector, located under right front seat. Connect DVOM between the black 2-pin seat belt switch terminals. Unbuckle right front seat belt. If continuity exists then let me know for further testing steps. If continuity does not exist, the right front seat belt switch needs replacing.
TIM BRUCE
  • 2004 CADILLAC ESCALADE
  • 187,000 MILES
Seat dont work drivers side
  • 108,300 POSTS
Chances are the switch is going bad. When it stops working, check to see if there is still a power supply to the switch. If there is, check for power out to the seat.
Friday, November 9th, 2018 AT 1:19 PM (Merged)
MARRVV
  • 2003 CADILLAC ESCALADE
  • 71,000 MILES
The heated seat on the driver side in our 2003 Escalade won't stay on, the fuse that it is tied to according to the owners manual looks good (it also the circuit for the ignition).
FIXITMR
  • 9,990 POSTS
Good possibility heating element is overdrawing current and has to be replaced.
2CP-ARCHIVES
  • 4,540 POSTS
  • 141,000 MILES
Heater seats dont work, were is the fuse or relay and under what name?
HMAC300
  • 48,601 POSTS
Fuse 24 in fuse box under dash however there is a tsb out tthat hte wire under the seat gets pinched an dyour seats don't work and a fw other things. Also check to make sure hanrness is rerouted if wires are hitting seat frame.
BOB
  • 2005 CADILLAC ESCALADE
  • 109,000 MILES
2005 escalade d/s front heated seat turns on for about 10 seconds than turns off p/s works fine until you turn on d/s side than turns off also.
When you turn on the drivers side heated seat it stays on for about 10 seconds. The passenger side works fine. But with the passenger side on if you turn on the drivers side it will turn off both seats.
Wife said seat got real hot one day the next time she went to use the heated seat this problem began.
RIVERMIKERAT
  • 6,110 POSTS
Sounds like the seat heater shorted out. Check it for shorts.
2CP-ARCHIVES
  • 4,540 POSTS
  • V8
  • AWD
  • 65,000 MILES
2005 Cadillac Escalade Four Wheel Drive Automatic 65000 miles. Every time I turn on the heated seats they turn right off on both sides.
2CP-ARCHIVES
  • 4,540 POSTS
The heating elements have shorted and need replacing.
CLEVELAND2005
Electrical problem
BUZZSAW
  • 1,198 POSTS
There shorted the elements need replacing.
DEWDRINKER04351
  • 168,000 MILES
If I don't turn on the drivers side, the passengers side stays on ok, but when I turn on the drivers side, after a few seconds, they both shut off.
RIVERMIKERAT
  • 6,110 POSTS
Check the circuit breakers. Check relays and fuses.
CADIEMAN
  • 3,544 POSTS
How the light goes out?
FACTORYJACK
  • 4,159 POSTS
You have a faulty heating element on the drivers side.
