2000 Cadillac Deville Crankshaft Sensors
NICKJONES
  • 2000 CADILLAC DEVILLE
  • V8
  • 85,000 MILES
I looking to replace the crankshaft sensors on my cadillac and I'm looking for a little guidance/instruction on how to proceed. Pictures would also be helpful. Thanks.
Do you
have the same problem?
Friday, November 7th, 2008 AT 11:30 AM
IMPALASS
  • EXPERT
Hello --
I have provided the info your requested.
REMOVAL PROCEDURE
CAUTION: Refer to Vehicle Lifting Caution In Service Precautions.
Raise and support the vehicle.
Remove the crankshaft sensor electrical connector.
Remove the crankshaft retaining bolt.
Remove the crankshaft sensor.
INSTALLATION PROCEDURE
IMPORTANT: Inspect the crankshaft sensor O-ring for wear or damage. If a problem is found, replace the O-ring.
Lubricate the crankshaft sensor O-ring with clean engine oil. NOTE: Refer to Fastener Notice in Service Precautions. IMPORTANT: Be sure to fully seat the CKP sensor into the engine block. Failure to fully seat the CKP sensor may cause a CKP sensor DTC to set.
Install the crankshaft sensor and the retaining bolt. Tighten Tighten the retaining bolt between 8-11 N.m (70-100 lb in) .
Install the crankshaft sensor electrical connector. CAUTION: Refer to Vehicle Lifting Caution in Service Precautions.
Lower the vehicle.
Operate the engine and inspect crankshaft sensor for engine oil leaks.
Perform the CKP System Variation Learn Procedure. See: Testing and Inspection Programming and Relearning
http://www.2carpros.com/forum/automotive_pictures/248015_84930635_1.jpg
Crankshaft Position (CKP) Sensor A
Center front of the engine, near the base of the engine oil level switch
Crankshaft Position (CKP) Sensor B
Friday, November 7th, 2008 AT 11:47 PM
Recommended Guides
