Lesabre trunk won't latch closed
ALTSPACE
  • BUICK LESABRE
92 buick lesabre 150k?
A friend needs help with her trunk.
The catch seems to function, but is electric, so I can't be sure. The trunk lid closes fully, and the catch moves freely. I presume this indicates an electrical failure, but don't know what part(s) to replace (or if it may be fixable as is).
Thank you very much for your time.
Do you
have the same problem?
Tuesday, May 22nd, 2007 AT 9:27 PM
LSUSSEL
With the trunk open press the trunk release switch and if you hear a noise, the clicking noise, then its the latch below that it goes into it, if you dont hear anything it could be the wiring, th4 ground wire or the switch.
Sunday, May 27th, 2007 AT 11:02 PM
