1994 Buick Lesabre Ground Wire on Starter Not stayin Hot
TEXAS409
  • 1994 BUICK LESABRE
Electrical problem
1994 Buick Lesabre 6 cyl Front Wheel Drive Automatic 160k miles
Ground Wire on Starter Not stayin Hot after letting go of key after being cranked
Do you
have the same problem?
Thursday, December 25th, 2008 AT 12:39 AM
BUDDYCRAIGG
  • EXPERT
There is no ground wire for the starter.
And the small wire (probably purple) is not supposed to have power after you let go of the key
Thursday, December 25th, 2008 AT 3:03 AM
TEXAS409
Yes it is a purple/white stripe wire, but most likely I think it wont stay runnin because security light on dash is blinking
Thursday, December 25th, 2008 AT 8:22 PM
BUDDYCRAIGG
  • EXPERT
That would do it.
I don't have any experience with resetting the security on a GM.
You should post a new questions describing what the car is doing and that the security light is flashing.
In the mean time, i'll do some snooping for an answer too.
Thursday, December 25th, 2008 AT 9:18 PM
BUDDYCRAIGG
  • EXPERT
I've got some more info
General instructions on pass-lock relearn:
So the engine cranks but it wont start? IS the security light flashing? If so try this
GM PASS LOCK RELEARN- Ignition to "run" position, try to start and let key return to "run" position
Approx ten minutes security light will go off
Turn key "off" and wait 5 seconds
Repeat 2 more times for a total of 3 relearns.
Turn key off, then start it
Friday, December 26th, 2008 AT 4:39 PM
TEXAS409
That didnt help me I tried almost everything but now, any one who has VATS problem with there lesabre I highly recommend you to get a VATS BYPASS KIT my car cranked 1st try
Saturday, December 27th, 2008 AT 8:33 PM
Recommended Guides
