Blower motor not working
PUFFNSTUFF
  • 59 POSTS
I'm after trying 2 other heater controls before I posted the problem and still nothing. Going to get pretty cold here now for the next few days so may be awhile before I get back at it again.I will try what you mentioned though. Can I rule out heater control if I was after trying 2 others so far? Thanks!
Saturday, February 4th, 2017 AT 4:18 PM
CARADIODOC
  • 33,752 POSTS
Probably can rule out the controllers, but it still makes sense to use a scanner to see what's going on. There could be a power, ground, sensor, or actuator circuit problem that is preventing the controller from generating the "fan request" signal. Admittedly, it's looking more like the problem is with the Integrated Power Module, but we'd like to know that for sure before wasting money on a new one.
Monday, February 6th, 2017 AT 3:06 PM
PUFFNSTUFF
  • 59 POSTS
I agree. I can take my chances and pick up an ipm at a scrap yard for $35 with the Fcm included.I also read that I can check resistance from pin 30 of the Fcm to relay ground pin. Is this possible?. Haven't been at it lately. It's been -24-25 windchills here this past few days. Suppose to warm up in the next few days. Thanks
Tuesday, February 7th, 2017 AT 5:08 PM
CARADIODOC
  • 33,752 POSTS
Nope. Forget terminals 30 and 87. You already verified that entire part of the circuit is working when you bypassed the relay and the fan ran.
Wednesday, February 8th, 2017 AT 7:24 PM
PUFFNSTUFF
  • 59 POSTS
Pin 30 on the Fcm sends a ground signal to terminal 85 of the relay. Is this correct? Can I check continuity between these two points for broken wire? Whatever is going on the relay is not receiving ground signal from Fcm for some reason. Milder here tomorrow so I will go at again for awhile. Thanks!
Wednesday, February 8th, 2017 AT 10:06 PM
PUFFNSTUFF
  • 59 POSTS
Hi! I removed the fuse box and this is what I discovered. Bit of corrosion and the bottom left plugin has a pin still left in it from the connector. Not sure if you can notice it in the pic.I'm more and more starting to believe this is the issue. Thanks!
Thursday, February 9th, 2017 AT 11:59 AM
PUFFNSTUFF
  • 59 POSTS
Don't look the best
Thursday, February 9th, 2017 AT 3:20 PM
CARADIODOC
  • 33,752 POSTS
! You found the cause of the problem! I'm so happy because there is a chance we can fix it.
I'm not sure which terminal you're referring to, but I see a bunch that need attention. The first step is to shine up the ones near my nifty arrows. If this would be on a tv or vcr, I would just unsolder the corroded terminals and replace them, but I don't recommend that for car computers unless there is no other choice but to junk it if it doesn't work. I used to purposely install a lot of electrical defects, ("bugs"), for my students to diagnose. One of them was a break in a copper trace on the Engine Computer for a '94 Intrepid. The bug was to simulate a failed voltage regulator. I drilled a hole through the board to run a wire to a switch, so the kids could switch the defect in and out as desired. I found out that some of these boards have more than the common copper traces on both sides. This computer had two additional layers sandwiched in the middle, and I drilled right through the circuit that ran one of the injectors. To avoid that potential problem with your computer, if there isn't enough terminal left to shine up, I would try to find a little remaining tab to solder a new terminal to. If that is not an option, solder a pigtail wire to the board, then run that out and attach it to the wire in the plug.
You're still confusing the function of the relay's terminals. 30 and 87 are the two contacts of the switch. They have nothing to do with 85 and 86. Those two are for the electromagnetic coil that runs the contacts. 30 and 87 are switching 12 volts on and off that goes to the fan motor. 86, (I think) or 85 gets 12 volts applied, and the other one gets grounded, (0 volts), to cause it to create the magnetic field that turns the contacts on. Those two circuits, (30 and 87), and (85 and 86), have nothing to do with the operation of the other one. In this case, one coil terminal and one contact terminal each have 12 volts applied, so for convenience, they are tied together inside the computer. That is simply done to reduce the number of wires going to the computer by one. For comparison, you can say the wipers and the radio both have 12 volts applied, so they could be run on the same wire, but the two systems are not related.
Where I added confusion to the story is when discussing the coil circuit in the relay. It needs 12 volts across it to operate. That means 0 volts on one terminal, (ground), and 12 volts on the other. Both are needed to turn the relay on and either one can be removed to stop it from turning on. Since 12 volts is applied to one coil terminal all the time, it is necessary to remove the ground to turn it off. That is actually how most computer-controlled circuits do the on / off switching. What is missing here is we aren't getting the ground on the coil terminal to turn the relay on, and that, I'm pretty sure, is due to the corroded terminals.
You're also going to have to address the mating terminals in the connectors. Given the extremely excessive amount of corrosion, I suspect it doesn't even pay to try to shine them up, then squeeze them tight to make solid contact. Where I would start is by snipping off the needed plugs from a similar vehicle in a salvage yard, then experiment on those first. There will be a locking wedge of a different color, often red, white, yellow, or blue, that must be pried out, then there will be some means of lifting a plastic finger to allow the terminal to be pulled out. You can use one of those terminals to install in your connector body, then splice the wires, or you can buy the correct terminals from the Chrysler dealer's parts department. GM has huge replacement terminal kits specific to each of their car models. Chrysler has every terminal available by the bag. In either case you just buy the number of terminals you need. They can even pick out the correct terminals for you based on application, without you even supplying an old one for comparison. Using original terminals insures they will clip into the connector body and remain firmly seated. When you have a melted connector body, as in an overheated ignition switch or head light switch, you can cut the melted part out, reinstall it that way, then solder on universal replacement crimp-on terminals and plug them in individually.
The reason I want you to practice on a salvage yard connector first is I also ran into a problem on a '97 Dakota. I made a REALLY big deal that no one was ever allowed to pierce a wire's insulation to take a voltage reading, and when I found someone had done that, they got the privilege of replacing that piece of wire, partly so moisture would not get in and corrode the wire, and partly so that poke mark did not become an illegitimate clue for the next person who was going to diagnose this bug. To replace a wire in one of the connectors for the Engine Computer, the terminal had to be removed so the new wire could be crimped and soldered to it. These connectors caused a whole new degree of frustration when trying to reassemble the terminals into the body. It took me more than a few hours to get one back together. I suspect there was some easier way to do it, but I never figured it out. I don't want you to pull your hair out if you have that same style of plug.
As long as I'm sharing all this wondrous information, Chrysler was real good to my Automotive program. The Intrepid was one of about 50 used to evaluate and fine tune a new assembly line. The Dakota was used by their head of training for all of Wisconsin and the UP for about six months. They didn't want either of those released to the public because they had been poked and prodded on so much. Instead, they donated them to one of three college programs they used for their remote training centers. Later, they even built an '03 Durango specifically destined for my program. We received it with less than three miles on it. Thank you, Chrysler.
Thursday, February 9th, 2017 AT 5:07 PM
PUFFNSTUFF
  • 59 POSTS
Thanks for all the communication on helping me out. The red arrow you drew pointing to a bad terminal. That terminal is completely broke of at the base. Going to see if I can pick up a used one somewhere and try it out, Have nothing to lose I guess. Don't know much about electrical just some basic stuff, hence the understanding of the relay. Do you know if I will have to program the other one? Thanks for your help!
Thursday, February 9th, 2017 AT 6:39 PM
CARADIODOC
  • 33,752 POSTS
I never got involved with programming 'puters. I have a rebuilt 2014 Ram truck now, but it was driveable when I bought it, and didn't need any electrical repairs. You might look for a local tv repair shop. The people there are good at soldering and coming up with make-shift repairs.
Thursday, February 9th, 2017 AT 7:36 PM
PUFFNSTUFF
  • 59 POSTS
I am happy to announce that it is fixed. Got a fuse box with Fcm included at a scrap yard for $40.00. Installed it and everything worked fine. I like to thank you for your guidance with this. Thank you so much for your help.
Friday, February 10th, 2017 AT 11:34 AM
CARADIODOC
  • 33,752 POSTS
Dandy! Can I assume the new module did not need to be programmed to your vehicle?
Saturday, February 11th, 2017 AT 12:09 PM
PUFFNSTUFF
  • 59 POSTS
Nope. It was already on the other fuse box. Just installed it connected the plugs installed battery and that was it. Maybe because I replaced the whole thing, fuse box and Fcm together as a unit.
Saturday, February 11th, 2017 AT 4:02 PM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 43,047 POSTS
Glad you could get it fixed please use 2CarPros. Com anytime we are here to help
Best, Ken
Wednesday, February 15th, 2017 AT 9:56 AM
SLINGELBAUGH
  • 2007 DODGE CARAVAN
  • 6 CYL
  • FWD
  • 48,000 MILES
I have a 2007 Dodge Caravan and yesterday, the fan/heater in the front of the van stopped working. The back blower/heater still works, just not the front. Any idea what it could be or how to fix it?
Thanks!
Tuesday, November 3rd, 2020 AT 9:07 AM (Merged)
MASTERTECHTIM
  • 4,749 POSTS
Check for power and ground at the motor, if thats good you need to replace the motor.
Tuesday, November 3rd, 2020 AT 9:08 AM (Merged)
DAVIDCAMPBELL
  • 110,000 MILES
2007 Dodge Caravan/ where is the relay for the blower? Part Number?
HMAC300
  • 48,601 POSTS
We dont' have part numbers but the relay shoud be in the integrated power module. Pic enclosed
KLESTER09
  • 88,000 MILES
The front blower motor just quit working no noises nothing
  • 108,300 POSTS
The front blower motor is under the dash on the passanger side. You need to start by checking to see if there is power to it. If there is, the motor is most likely bad. If there is no power, you need to work back through the resister, relay, and to the switch to see where power is lost.
