What is the Torque Specs for the front hub.
KHANDYMAN462
  • 1999 DODGE DURANGO
  • 116,000 MILES
What is the Torque Specs for the front hub retainer bolts and axle nut on a 4 X 4?
Monday, April 1st, 2013 AT 11:48 AM
HMAC300
  • 48,601 POSTS
123 ft lbs on hub bolts
180 ft lbs for axle nut
Read this guide first, it will help. Not vehicle specific, but will give you an idea of what you are getting into
https://www.2carpros.com/articles/bearing-hub-replacement
Monday, April 1st, 2013 AT 2:08 PM
STACYLYNN7
  • 32 POSTS
  • 2003 DODGE DURANGO
  • 4.7L
  • V8
  • 4WD
  • 183,800 MILES
I need to change my assembly hub bearings and I need to know if I have two wheel ABS or four wheel ABS.
Sunday, December 2nd, 2018 AT 11:25 AM (Merged)
CARADIODOC
  • 33,742 POSTS
Look at the rubber brake flex hose going to either front brake. The front hubs for four wheel ABS have a wheel speed sensor, and its wire harness is smaller in diameter than the hose, and is clipped to it. The two run parallel to each other, and about an inch apart. Follow the two steel brake lines from the master cylinder, and you will see them go into a fairly large hydraulic controller with another three or four lines coming out of it. That controller will have a lot of wires plugged into it.
If you have rear-wheel-ABS, (RWAL), there will be no wheel speed sensors or wiring at the front wheels. Most models have only a single sensor on top of the rear axle's center section. The two steel lines leaving the master cylinder go straight down to a small brass valve assembly, (about four inches long and one inch wide), bolted to the frame. Three lines leave that block. Two go to the two front brakes. The third one, on the rear, goes to a dump valve assembly bolted to the frame rail, close to right under the driver's feet. A single line leaves that to go to the rear axle.
Trucks usually also have a sticker in the glove box listing the optional equipment.
The bearing assemblies are the same for both applications. If you use a four wheel ABS bearing on a vehicle with rear-wheel-ABS, just do not connect the wire. Wind it up and tie it out of the way.
STEVE W.
  • 12,970 POSTS
The best way to tell is to look under the truck at the current front hubs. If they have a speed sensor you have four wheel ABS.
Or you can go to:
https://www.mopar.com/chrysler/en-us/my-vehicle/dashboard.html
Create an account and enter your VIN number. They will give you a build sheet with all the options your vehicle has.
STACYLYNN7
  • 32 POSTS
Here is a picture I cannot tell. Can anybody tell by photo?
STEVE W.
  • 12,970 POSTS
I do not see a speed sensor wire, but they would normally be somewhat out of that picture. Turn the wheel the other way and take another picture more to the upper control arm, but I suspect you only have rear wheel ABS.
