Check Engine and TCS light
SHESHE712
  • 2003 ACURA TL
  • 6 CYL
  • FWD
  • 165,671 MILES
Lately, my car has beening hesitating a little upon aceleration. Little jerking nothing too hard, then today as I'm driving the Check engine light and TCS both comes on and the car is really jerking like it wants to shut off. Do you know what this might be?
Thank
Tuesday, September 1st, 2009 AT 12:09 PM
KHLOW2008
  • 41,815 POSTS
Hi Sheshe712,
When the Check light shows and misfiring occurs, the TCS light would come on so they are related.
You would need to retrieve the trouble code to find out what is causing the CEL to show. I would suspect it to be misfiring codes, P0300, P0301 - P0306 and/or P1399.
This could be caused by fault with the igntion coils or spark plugs.
Autozone provides free scanning, get it done and let me know the exact trouble code so I can understand and advise on what needs to be done to rectify problem.
Tuesday, September 1st, 2009 AT 1:09 PM
GOSWICKC
  • 7 POSTS
  • 2003 ACURA TL
  • 3.2L
  • 6 CYL
  • FWD
  • 69,300 MILES
The maintenance required light comes on when I start my car but then goes out. The check engine light comes on when I crank the car and stays on while driving. My car slows down sometimes while I am driving and when I press the accelerator it will hesitate and/or stop going. Then I pull over and stop and turn ignition off and right back on and put it in drive and it will not move. So I turn ignition off and wait four or five minutes and start the car again and it will go down the road for a few miles and start doing the same thing all over again. The TCS light comes on sometimes when driving but goes back off in a few minutes. Can you please tell me what the problem might be. Also, will it cause damage to keep driving it? I would to get it to a mechanic but I am not sure if it will make it there.
Wednesday, March 13th, 2019 AT 6:01 PM (Merged)
HMAC300
  • 48,601 POSTS
Have it scanned for codes auto parts does for free then get back to us with the code number.
GOSWICKC
  • 7 POSTS
Thank you! I took my car to O'Reilly's for a diagnostic scan. It gave the following codes:
PO740 - torque convertor
PO706 - transmission range sensor
PO730 - torque convertor or shift
solenoid
PO700 - transmission fluid
The transmission fluid was checked, and it was 3/4 to no more than 1 quart low.
What is your advice?
HMAC300
  • 48,601 POSTS
Have a trans guy look at this it may be time to rebuild the transmission or at least the torque converter may be bad.
GOSWICKC
  • 7 POSTS
The trans guy is located a long distance from me. So I had a regular mechanic to do a diagnostic scan since he is close by. It revealed the following codes:
PO730 - Hydraulic solenoid
PO740 - Torque convertor
2CP-ARCHIVES
  • 4,542 POSTS
  • 2003 ACURA TL
  • 121,000 MILES
I have a constant check engine light on my 2003 Acura TL which I continue to drive. The car is hesitating and the gas mileage has taken a dive. Last year I had the same issue and I poured Restore in the tank and the light went out. This time it was a no go. According to the manual the problem lies within the emission system- what would be your first guess as to the cause of the light? Thanks for your time. Tim B.
  • 108,192 POSTS
Tim:
Have the computer scanned to identify trouble codes. Most parts stores will do it for free. Then you will know what is causing the light to come on.
HMAC300
  • 48,601 POSTS
Ya but the mechanic probably doesn't know transmissions that well like most of us that is why I said to have a trans guy look at it so he can check pressures if needed or go by experience on what is causing the problem.
HMAC300
  • 48,601 POSTS
You could replace the solenoid and have the same problem that is why I send people to transmission shops when they run into a condition like yours. As trans shop guys know these things a lot better than us mechanics.
GOSWICKC
  • 7 POSTS
Ok. Thanks! So are the codes from the big diagnostic scanner correct? Do these codes mean anything to the trans guys?
HMAC300
  • 48,601 POSTS
Yes they are good and the trans guys should know what to do
NEDU
  • 7 POSTS
  • 2005 ACURA TL
Six cylinder two wheel drive automatic 58,000 miles.
A check engine light came on at around 57,000 miles. I took it to the Acura dealer and they want to replace a sensor. The care drives fine other than the check engine light (which is going to cost about $500.00 to fix) is this something I can do myself? Do I have any other options?
Thanks,
Nadeem
LEGITIMATE007
  • 5,121 POSTS
It all depends what the sensor is, did they tell you which one you need?
GOSWICKC
  • 7 POSTS
Thank you guys for your help! What type of pressures are you referring to for the trans guy to check? Would the transmission fluid being 3/4 to 1 quart low have anything to do with getting the codes PO730 and PO740?
NEDU
  • 7 POSTS
Here is what it says on the bill for the diagnose charge: Part 57812 code P1172, B1S1 A/F sensor out of range.
I called the BBB Autoline to find out if this kind of repair is covered under the extended warranties (8/80) and they are not cooperative at all.
Thanks,
Nedu
HMAC300
  • 48,601 POSTS
The low fluid could or it could also be the converter going bad.
LEGITIMATE007
  • 5,121 POSTS
P1178 O2 sensor signal circuit slow switching from rich to lean (bank 1 sensor 1).
The other one I am not familiar with. If you know someone handy and semi mechanically inclined, they can change that o2 sensor, easily.
GOSWICKC
  • 7 POSTS
Ok, thank you! What kind of pressures are you talking about that the trans guy would check?
NEDU
  • 7 POSTS
Where can I find instructions to do it myself? I was searching online but could not fiend anything for my car. Appreciate your help.
Thanks,
Nedu
