Air conditioner is not working
BSAG
  • 2004 NISSAN PATHFINDER
  • 3.6L
  • 6 CYL
  • 275,000 MILES
Air conditioner compressor comes on it does not cycle, but it blows hot air. I checked blend air motor it is working fine.
Do you
have the same problem?
Thursday, May 19th, 2016 AT 5:57 PM
HMAC300
  • EXPERT
Check system for low Freon pressure. It also depends if this is automatic temperature control and whether or not it is LED grade as all of these are different. If it s one of the aforementioned the controls it will need to be scanned for codes which auto parts cannot do, it has to be scanned with a professional grade scanner. A mechanic will have to do the scan for you.
Friday, May 20th, 2016 AT 7:40 AM
Recommended Guides
