Morris minor 1000
SANDUN
  • 1961 ALL OTHER MAKES ALL OTHER MODELS
Dear Sir - Distributor of the morris minor 1000 have an adjustment circle(Vernier) under the vacuum advance unit, What is this, for what?
Thursday, August 11th, 2011 AT 4:11 AM
MHPAUTOS
  • 31,938 POSTS
This is for minor timing adjustments which may be required for poor fuel or high altitude, normally you keep the adjustment in the central position and leave it.
Thursday, August 11th, 2011 AT 8:15 AM
SANDUN
  • 34 POSTS
Pleas explain me "normally you keep the adjustment in the central position and leave it." I have Put it (Platinum point nipple that touch with router )central of the router, is it ok?
Thursday, August 11th, 2011 AT 10:15 AM
MHPAUTOS
  • 31,938 POSTS
The points are set with the rubbing block on the high side of the 4 sided rotor, this is the maximum opening of the points, the vernier adjustment is set in the middle of the adjustment, for practical purposes this in not normally adjusted, adjusting will advance or retard the timing, so set vernier in the middle and do a conventional timing adjustment.
Thursday, August 11th, 2011 AT 1:11 PM
CJ MEDEVAC
  • 11,004 POSTS
JUST OUT OF CURIOSITY
WHAT ARE THE DIMENSIONS OF THE "SQUARE" PART OF THE DISTRIBUTOR SHAFT. THE PART THAT THE POINTS RUB AGAINST.
PLEASE BE REAL ACCURATE.A MICROMETER OR DIAL CALIPER MEASUREMENT IS HOW CLOSE YOU NEED TO BE
SEEMS YOU REALLY ARE HAVING PROBLEMS WITH THAT CAR.I MAY HAVE SOME IDEAS THAT MIGHT HELP.I HAVE BEEN DOING A LITTLE RESEARCH. BUT I NEED THE DIMENSIONS
THE MEDIC
Friday, August 12th, 2011 AT 1:21 AM
SANDUN
  • 34 POSTS
Pleas tell me, what is the MIDDLE of the Vernier that you say
Friday, August 12th, 2011 AT 3:31 AM
SANDUN
  • 34 POSTS
I think that is the case, to heating my ignition Coil, be kind and give me a Best Answer, REALLY I HAVING PROBLEMS WITH THAT case - Pleas help me
Friday, August 12th, 2011 AT 3:38 AM
CJ MEDEVAC
  • 11,004 POSTS
I'M WORKING ON A POSSIBLE SOLUTION, TO ELIMINATE THE POINT SYSTEM. GO TO INEXPENSIVE ELECTRONIC IGNITION!
YOUR CAR IS NOT ON THE LIST
I JUST BOUGHT ONE FOR MY JEEP.(1946 WILLYS)
SIMPLE TO INSTALL ON MY JEEP. NO BOXES. DISTRIBUTOR INSERT AND COIL ONLY. MAY MODIFY TO FIT YOUR CAR!
I WANT TO COMPARE DISTRIBUTOR SHAFT SIZES. JEEP VS: MORRIS MINOR 1000
BE ACCURATE WITH "MM"!
THE MEDIC
Friday, August 12th, 2011 AT 4:22 AM
SANDUN
  • 34 POSTS
Dear sir - mhpautos (expert) - oH I See, I think that you Say ''set in the middle of the adjustment" meaning of that to give Space for auto Adjust from the Vacuum Advance Unit, So you Saying me to Adjust vernier to middle, that is normal adjustment - Am I ok, -on the situation ignition coil heating? After adjustment to middle- Am I have to Readjust the Platinum Point Gap?
Friday, August 12th, 2011 AT 5:17 AM
MHPAUTOS
  • 31,938 POSTS
Set vernier, then points then timing, replace condenser and coil if not new already.
Friday, August 12th, 2011 AT 7:27 AM
SANDUN
  • 34 POSTS
Mr Mhpautos - I set vernier, set point and timing, not replace condenser ( I think it is good)- then I went test run about 4 km after that the morris minor 1000 car was not Stop, But the ignition coil ( Bosch coil - new one, 12 v- Unresistant coil ) Heat, the heat not petty, can touch but warm - I think, if I go long Trip on my car, the coil is over heat then Stop- So I afraid to go far ? - How test the Distributer condenser Bad or Good?
Monday, August 15th, 2011 AT 4:14 AM
MHPAUTOS
  • 31,938 POSTS
If the old points looked blue and had splatter marks from arching, the condenser will be faulty.
Monday, August 15th, 2011 AT 4:19 AM
SANDUN
  • 34 POSTS
Pleas tell me How to check the Distributor condenser bad or good?
Tuesday, August 16th, 2011 AT 3:52 AM
Related Ignition Distributor Content
