EGR Solenoid Does What Exactly?
I Would Like A Clear Explanation Of What The Egr Solenoid On Top Of Engine Does. Not The Egr.
Todd Free
MITSUBISHI TRITON
Batterie
My Batteries Died And Now I Don't Know How To Get It Open
Pete vargas 559
BMW 528
Car Will Not Turn Off?
The Vehicle Has Been Sitting In The Garage For The Past Few Years, Used To Work Fine. Recently Turned On The Car, But When It Comes...
uwas
MAZDA RX7
Power Steering Stops Working At Low Speeds And While...
Power Steering Is Lost At Very Slow Speeds.
JC Wright2
CADILLAC CTS
Need Wiring Diagram For Car Stereo Wiring?
I Try To Get A Description, But I Need But I Don’t Think I Did It Right. Basically, I Have Some Cut Wires. Where Are You Hook Up The...
Jrfinds
CADILLAC ELDORADO TOURING
Codes P0171 And P0172?
My Vehicle Listed Above Sx Model Has Started Throwing The Above Codes. They Both Pull Bank 1. I Didn't Notice Any Difference In Driving...
Kimberley Colton
SUZUKI AERIO
Hard Starting?
Hello All, I Rebuilt A 302 Efi And Have Replaced Almost Everything In The Engine Bay To The Back Of The Rear Tank Brand New. I...
tang_j
Shifter Won't Release From Park, Most Of The Time?
My 2007 Saturn Ion 2.2l Automatic While Parked In My Driveway Which Has A Slight Incline Started To Periodically Get Stuck In Park. At First...
Jason Miranda
SATURN ION
Fuel Injector O Ring
Our Car Is Leaking From The O Ring We Change The O Ring And Now When We Put The Car Back Together It Makes A Clicking Sound When Starting
Dezzii
Engine Management Light?
Hey. I Have The Car Listed Above Se Model (approximately 117,000 Miles On Clock) Which Has Engine Management Light On. Scan Showing Misfire...
June Pollock
BMW 318I
Cooling Issue And Running Rich?
In The Past Few Months, I Have Done A Lot Of Needed Work For My Vehicle Listed Above Express 3.6l V6. I Had A Check Engine Light Come On...
2011dodge
DODGE AVENGER
Check Engine Light On And Check Gas Cap Message On...
I Have The Car Listed Above With 130,000 Miles. I Haven’t Had Any Issues Other Than A/c Going Out At 110,000 And Alternator Afterwards....
MotztheGOAT
FORD FIVE HUNDRED
Speakers
My Rear Factors Subwoofer Started Making A Lot Of Noise So We Cut The Wires To It Now We’re Getting No Power To Rear Speakers Or Subwoofer
masoncade
Vibration When Braking?
There Is Vibration When You Hit The Brake, But It's Not So Much In The Steering, There Is Some, But It's In The Front Wheels....
BMW 335
Bent Rim, Repair Or Replace It?
I Recently Bought The Car And Had My Mechanic Replace The Tires And Afterward He Said My Rim Was “severely” Bent. I Went And Checked For...
2nd gen tc
SCION TC
Poor Acceleration?
I Have The Truck Listed Above 2500hd And While Pressing On The Accelerator It Seems To Have A Delay And Takes A While To Accelerate Normally...
Ronald DeVold
My Mother's Car Was Still In And Taken To The Impound Lot When We Got The Car Back It Was Missing A Lot Of Fuses A Lot Of Relays In The...
Gmjacobs
Spark Plugs Installation Issue?
When Installing Spark Plugs, They Won't Stay Put. The Ignition Coil Is Good. What Is The Tool That Keeps The Spark Plugs In Place.
holmanii1985
MERCURY MARQUIS
Will Not Start, Running Lean, Cylinder Misfire?
The Car Listed Above Is A Gls, 2.4l L4.180,000 Miles, Approximately 50,000 On The Engine That Was Replaced By Hyundai Under A Recall. Car...
kgundersen21
Wiring Behind Car Radio?
I Am Trying To Find Wire Diagram For Ecm Wires That Run Behind, Under The Dashboard There Are 3 Wires That Or Cut Not To Car Radio. My Abs...
Jrfinds
CADILLAC DEVILLE
Headlights Won't Come On
A Week Ago I Bought This Car And Was Told The Cluster Was Changed In It So They Did Not Know Actual Mileage I Test Drove It It Drove Fine I...
Mystyn Drain-Butcher
VOLKSWAGEN BEETLE
After Installing A Water Pump My Alternator Started...
After Installing A Water Pump My Alternator Started Smoking After Testing For Leaks On A Drive. When I Checked It After I Got Home, There...
mrtoneg
Change Starter
How To Get The Starter Out.
Peje
1980
JAGUAR XJS
Cranks Over No Start I Hear The Fuel Pump?
This Happened The Other Day And I Reset The Security System And It Started Happened Again Reset It, It Ran, Now It Won't Start Even If...
Angela Meik
OLDSMOBILE ALERO
It Started Making A Popping Sound Out The Exhaust?
I Went And Replaced The Heads And Put It Back Together And Got Everything Plugged In And When I Started It, It Ran Fine For A Little Bit...
Brycerpoppy
677
678
679
