Where Is The Horn Relay Located?
Or Is There One? I Found A Couple Of Diagrams, But They Don't Look Like Under The Hood. Thank You!
termaxco
CHEVROLET CELEBRITY
Service Manual?
My Car Needs A Lot Of Work Done And I Don't Want To Keep Asking Questions Every Time. I Was Wondering If Someone Could Send The Service...
ryurei4444
CHEVROLET SPARK
How To Adjust Parking Brake?
The Parking Brake On The Van Doesn't Do Much. In Neutral The Van Would Roll Down My Driveway (just A Regular Driveway), And The Parking...
StuartK
CHEVROLET EXPRESS
Automatic Transmission Oil Cooler Line Fitting?
I Need To Replace The Acdelco 15718023 Automatic Transmission Oil Cooler Line Fitting. I Can't Find This Part Anywhere. Napa And Dorman...
compnc55
Location Of Odb Output On Isuzu 1992 Pickup
I Have An Odb2 Reader But Cannot Find The Cable On The Pickup. Is It A 2 Pick Connector By Trunk Pull Latch? Then To Read Code Short...
phicks2121
ISUZU TRUCK
Where Is The Odb Output Located?
I Have An Odb2 Reader But Cannot Find The Cable On The Pickup. Is It A 2-pick Connector By Trunk Pull Latch? Then To Read Code Short...
phicks2121
ISUZU TRUCK
عطل في قير اتوماتيك
Hello, I Have A Problem With The Cvt Automatic Gearbox Hyundai Accent 2016 Model. Malfunction Code P0741 Has Been Renewed Inside The...
Fahd1
HYUNDAI ACCENT
Camshaft Sensor Which Side It Is Bank 1 Or 2?
I Finished Replacing The Valve Cover Gasket On This One But I Have This Code, How Can I Tell Which Side It Is Bank 1 Or 2. This Is Only...
BMW 550I
A/C Blower Motor Fan Speed Is Either Super Slow Or...
The A/c In My Truck Gets Cold And Can Fluctuate Between Temperatures As Needed Very Well. However, It Seems The Fan Speed Is Either Super...
SCBreck
Oil Power Out Top Of Oil Pan When Engine Running?
Oil Pump Gear That Time Belt Spins Broke Meaning It Was Spinning Freely Without Pumping Oil. Noticed This When Car Pulled Out Of Garage...
pkcom81
Motor And Transmission Swap
No Crank With Key
Stacy Olsen
Valve Clearance Setting Procedure Needed?
Please May You Assist With The Valve Clearance Settings And Procedure, It Would Be Kindly Appreciated. Od Is In Km, Not Miles. The Vehicle...
Natasha Boucher
CHEVROLET SPARK
OBD Code C1237: Primary Pressure Sensor Signal?
Suddenly I Have A Notice On My Display, Check Brakes! The Car Was Suddenly Stopped, Maximum Speed Is 20, And When I Push Brakes I Hear...
Aymen
KIA OPTIMA K5
PCM/ECM Testing?
So, I Need To Do A Test On My Car To See If It's The Pcm/ecm That's Preventing My Car From Starting And Was Wondering Step By Step...
Luucufer
A/C Intermittently Stops Blowing Cold Air?
So, Basically, The A/c Works, I Had A Leak And Had To Get A New Compressor, And Everything Seemed Fine Until Only A Couple Of Days After...
blancaestela944
HUMMER H3
Idle Control Valve P0505, Wiring Diagram Needed?
I Think Somehow The Wires Coming From The Harness To The Control Valve Have Been Crossed, Is There A Schematic For The Colored 4 Wires.
Ronnie Labastida
Fuel Pump Installation?
So, My Husband And I Had To Replace Our Fuel Pump On Our Truck For A Second Time Last Month And Now My Gas Gauge Doesn't Work. It Is...
beauty6183
Code P0496?
Replaced Switch/purge Solenoid. Check Engine Light Remained. Do I Need To Clear The Code, Or Will The Code Clear Itself After Normal...
RJ112431
Where Is The Crankshaft Position Sensor Located?
Location Of The Crankshaft Position Sensor.
Chad Gardner
I Put A New Key Mobile Liser On The Key Switch They...
Turn The Key On All The Lights Come On Doesn't Do Anything No Noise I Ran A Wire From The Stater An Turns Over But Won't Start
Tim Epling
CHRYSLER SEBRING
When I Turn My Headlights On The Motor Loses Power And...
If I Let Off The Gas And Then Give It Gas Again It Runs Fine, But The Cruise Control Will Not Start Back Unless I Turn The Headlights Off.
janicelowe
KIA SPORTAGE
The Radio Started Staying On For About Ten Minutes...
Today My Radio Started Staying On For About 10 Minutes After Cutting The Car Off, Exiting It, And Opening And Closing The Door. Before...
Flippa334
BUICK LA CROSSE
Engine Will Not Crank Over?
It Shut Off, Tried To Start And No Crank. Beforehand Started Just Fine With No Hesitation At All.
Jesse Michael
CADILLAC DEVILLE
Ignition Coil Firing Order
I Need A Diagram Showing Ignition Coil Firing Order
Wattsmark
Where Is The Fuel Pump Relay Located?
Fuel Pump Relay Location.
Wayne David Roberts
1983
CADILLAC CIMARRON
649
650
651
