Timing Chain Broke 98 Explorer XLT 4x4
After Stopping At The Grocery Store I Parked And Went In, Made My Purchases And Got Caught At The Door Of The Store By The "don't Steal Our...
tpyland
Excessive Oil Consumption
I Just Got My Intake Manifold Gasket Fixed On My1998 Isuzu Rodeo, And Now It Is Going Through Oil Like Crazy. I Just Did An Oil Change...
aaronmat
4 Cylinder Mazda 626 Water Pump
My Girlfriend Has A 1996 Mazda 626, With 130,000 Miles On It, It Has The 4 Cylinder Engine. The Water Pump Has Gone Bad And Needs To Be...
mdbarnes
1962
MAZDA 626
Ford F159 Eats Solenoids !
1988 Ford F150 Has Cooked 4 Solenoids In 10 Weeks! I Am A Gm Person & Don't Undersatnd This Trucks Hunger For Them - Any Thoughts Or...
jimmygmc
1915
89 Honda Accord Transmission Slipping And Shifting...
I Took My Vehicle In For A Diagnostic On The Transmission And The Tech Told Me That The Throttle Cable For The Transmission Had Broken And...
bgordon
2000 IMPALA COOLING FAN STAYING ON
The Cooling Fan Stays On After I Have Shut Off My Vehicle? It Doesn't Do It All The Time But Enough Now To Worry About It. Mechanic Doesn'...
WINKY
1981chevy Stepside Wont Start
The Battery Is Fully Charged, I Turn The Key All Lights Work Fine But When I Turn To The Start Position Nothing Happens. Is My Starter Bad?
john_h01
1981
I Can Feel The Stutter Of My ABS Brakes At A Low...
I Can Feel The Stutter Of My Abs Brakes At A Low Braking Speed. This Is An Intermittent Problem. I Also Hear The Hum Or Whine Of The Abs...
emilynelms
JAGUAR XJ6
Squeaky Brakes
My 2001 Ford Ranger Squeaked From The Front End Wheni Drove And Braked. I Had A New Rotor Put On The Right Side And The Other Was Turned....
eoj_73
Ecm Trouble Codes
Where Can I Get The Trouble Code (check Engine Light Flashes) List For An '85 Chevy Celebrity V6 2.8l Mpfi? Seems It Should Be Available...
lootz
2002 Saturn Vue Head Gasket Replacement Cost
Car Is A 2002 Saturn Vue V6 With Approximately 45,000 Miles. I Am Just Looking For Some Kind Of Approximate Idea How Much It Will Cost To...
kevin_co
96 Grand Am Door Locks
The Door Locks On My 96 Grand Am 3.1 Have Stopped Working, They Lock When It Is Put Into Drive And Unlock Only When The Car Is Shut Off...
biggmann
Saturn Running Rough
I Have A 1992 Saturn Sl1, Manual Transmission, With 225,000 Miles On It. When I Try To Start It Every Morning It Won't Stay Started Unless...
Groenbeck
1989 Silverado Z71 Brake Light Code
2 Parter Parking Brake Code Flashes "99" #2 Driving Down The Road Speedometer Drops Out, Tap On Dash Comes Back Up To Speed. Where Do I...
jross
Thermostat Replacement For Astro Van
Where Is The Thermostat On 1995 Chevy Astro Van?
Diamond Jim
CHEVROLET ASTRO
I Got VERY LITTLE Heat Coming Out Of The Vents.I Also...
One Day Last Week, On My Way To Work I Had No Heat, I Could Hear The Damper Moving From Pos. To Pos. But No Blower. Left Work To Go Get...
spctcl
2000 Cadillac Catera Is A Lemon
I Have A 2000 Cadillac Catera My First Issue Was That I Had A P0171 And P0174 Error Codes. Which Cadillac Stated Was My Catalytic...
cherylmccorry
CADILLAC CATERA
98 Chevy Fuel Pump
Hello All I Have A 98 Chevy 1500 Truck And The Fuel Pump Went Out. I Have Just Bought A New One But Not The Assembly Just The Pump Motor....
scott50
Aiming Headlites
Hi All. Sorry For My Stupidness, But I Have A 1996 Ford Ranger. I Know I Asked Before, But I Had The Wrong Year For My Truck. ( I Havent...
Young
1995 Chevy Lumina Missing While Cold Outside
My Car Will Run Fine As Long As The Tempature Out Side Is On Or Above 40 Degrees If It Gets Below 40 It Will Start Up Fine And You Drive It...
tonys68
I Have To Replace The Harmonic Balancer?
I Have A 1991 Ford Probe. I Have To Replace The Harmonic Balancer In It And Im Having A Hard Time Getting The Old One Off. The Manual Doesn...
jesse
FORD PROBE
2000 ASTRO
My 2000 Astro Bogs When You Accelerate. Fuel Pressure Is Good (58 Lbs.) Fuel Filter Has Been Changed. The Strange Thing About This Problem...
wrscomncents
No Running/tail/brake Lights On 1995 S-10
Only Lights That Work Are The Head Lights And The Amber Lights In The Front Bumper. No Tail Lights At All In The Back And The Amber Lights...
BrianWI
1996 Explorer - Change Plugs
I Apologize If This Has Been Asked Before But It Seems To Be A General Problem- I Would Appreciate If Someone Could Give Me Step By Step On...
Dave110
94 Buick Regal Stall Problems
I Have A 1994 Buick Regal Custom With 74,000 Miles On It. (Incidentally, I Do Not Reccomend This Model As It Has Been Nothing But Trouble...
nomorebuicks4me
BUICK REGAL
20237
20238
20239
