Can't Get Old Pin Out Of Axle
My Husband Is Putting In A New Front Axle In A 93 Suaru Legacy L Sedan And Cannot Get Pin Out Of Old One Any Suggestions
prayerlady
SUBARU OTHER
98' Ford Taurus Lights Dim At High Rpms
When The Prm's Get Between 4k To 5k The Lights Dim. Headlights, Dash Lights, Radio And The Battery Light Come On But As Soon As The Trans...
Trout
98 Altima Loud Thumping Noise From Right Front...
New Front Brake Pads A Couple Of Months Ago. Everything Looked Fine At That Time. No Leaks Or Anything. Recenty While Driving, I Am Hearing...
dshillis
2001 Eclipse GS - Idling Problem
I Have A 2001 Eclipse Gs With 74,000 Miles. Back In Dec '05 I Had The Timing Belt And Balance Shaft Belt Replaced, And Just Yesterday I Had...
aeveringham
What Is Shaking?
I Have Just Purchased A 1998 Ford Explorer 4x4 Suv. When I Go Over Bumps The Stearing Wheel Shakes And I Have A Real Hard Time Keeping The...
Chawche
Brake Lights.....refuse To Go Off
Hello Everyone Lst Time Poster Here, Have A 1999 Toyota Camry And My Brake Light Will Not Go Off, Ive Tried To Play With The Emergency...
blk buttah
LOUD NOISE 1998 CAMRY WHEN START
I Have Had This Loud Noise For At Least 3 Yrs. Sounds Like My Car Is Popping Popcorn When I Start It. It Is A Rattling Noise. I Had Timing...
asja11
2003 Nissan Sentra Will Not Start
I Have A 2003 Nissan Sentra That Was Starting Up Just Fine A Few Days Ago Before I Moved From Las Vegas To Alaska. It Got -24 Degrees The...
dorito1
VW Cabrio Alarm Stuck, Car Won't Start
My Girlfriend's Cabrio's Alarm Goes Off Everytime She Opens The Door Or Puts The Key In The Ignition. I Believe It Is The Anti-theft Device...
jeffharding
Engine Dies When I Take My Foot Off Of The Gass
I Have A Jeep Grand Cherokie The Batery Ran Flat Some Time Ago But When I Jump Start It With A Jumper Cable It Starts But Any Time I Take My...
odonald
CHRYSLER GRAND VOYAGER
Is This True?
Radio Fuse Is Blown & Took It To The Mechanic Cuz I Thought It Might Be Something Else. He Told Me He Couldn't Replace It B/c It Would Run...
ihatemycar
CHRYSLER OTHER
What's That Sound
What's That Sound The Car Makes When The Fan Belt Needs To Be Tightned?
ihatemycar
CHRYSLER OTHER
Airy Sound
1997 Chrysler Sebring Lxi, 118,465 When In Idle Car Makes An Airy Sound From The Engine Also Leaking Oil In The Front, Pressure Gauge Goes...
ihatemycar
CHRYSLER SEBRING
2003 Isuzu Rodeo Check Engine Light AGAIN!!!
:evil: When I Started My Car This Morning The Check Engine Light Came On Again. I Bought It Brand New In 2003 And It Has 42,500 Miles On...
ennui-ology
Altenator
I Have A 1990 Pontiac Sunbird And Something Is Draining The Battery. The Altenator Was Checked At Auto Zone And They Said It Was Working....
PyroKa
CHRYSLER OTHER
Ford E-150 Orifice Tube
I Have A 88 Ford Conversion Van, 300cid 4.9l Six Cylinder With Front And Rear Air And Need To Replace The Ac Compressor And Orifice Tube. ...
cm1
1915
Honda Civic 94 Overheating Even When Running
Hello There, The Car Is About 100 000 Miles. I Kept It In Good Condition. Recently, It Would Overheat Even When Its Running. Ie Running...
roi
1990 Integra Needs Help!
My Front Right Passenger Tireis Bent In A Little Bit Causing My Car To Drive Funny, Everytime I Turn It Feels Like My Tire Is Going To Fall...
phillie_3814
1995 Buick Skylark
This Car Strarts Up Real Good. But, When It Comes Down Off Of Fast Idle It Wants To Spit And Sputter And Try To Stall Out For A Few Seconds...
rodney025
BUICK SKYLARK
Water Pump Replacement Labor Time
My Wife And I Just Recently Had The Water Pump On Our 1997 Olds, Delta 88, 3.8 Mfi Replaced. The Dealer Charged Us 3.5 Hours Labor For...
mechanic
1997 Astro
I Have A 97 Astro Van. It Stopped Running And I Cant Figure Out Why It Wont Start.I Replaced The Fuel Filter And I Can Hear The Fuel Pump...
kmclean
Ignition Tumbler Loose
I Have A 93 F-150 105000m. I Turned The Key To Start, And All Of A Sudden The Tumbler Went Loose. I Had To Pull Some Fuses To Get The...
edhe653
Vibration When Stop My Car
Neon 2002. 37,300 Mileage. Automatic Transmission. I'm Driving My Neon And It Behaves Good. When I Stop The Car, Revolutions Drop From 900-...
paconeon2002
Ticking Noise - Dissappers After Running A Short While
I Have A Lc 100, V8, 2000 Model. When I Drive The Car I Hear A Ticking Noise From The Engine Which Dissappers Afer A Few Hundred Yards....
superlusso
93 Subura Impreza Gauges Don't Light Up
1993 Subaru Impreza Awd L When I Turn The Headlights On The Dash Lights Do Not Light Up (speedometer And Gauges) I Looked For A Fuse But Was...
xBOOTSx
SUBARU OTHER
20196
20197
20198
