DTC's P0172 And P0175 1997 GMC 5.7 Sierra 1500
I Have A 1997 Gmc 1500 With A 5.7 L Vortec And I Keep Getting Dtc's P0172 And P0175. I Have Replaced The Mass Airflow Sensors Twice, New...
crank65
Hesitates Intermittently
Hello. 1992 Ford Tempo I Have A Problem With This Car That I'm Not Sure Is Serious Or Not. After I Have Come To A Stop, Every Once...
toadybum
FORD TEMPO
I DESPERATLEY NEED ADVICE! 99 Merc Tracer Flexplate/...
I Need To Know What Would Cause The Flexplate/flywheel To Crack Around The Crankshaft Bolts And Cause The Flexplate/flywheel To Rub Back Of...
bboos
1996 Dodge Neon
How Do I Locate And Replace The Thermostat In A 1996 Dodge Neon With 131000 Miles.
Jenn
I Just Got An 87 Ranger 2.9 Litre
I Got An 87 Ford Ranger 2.9 Litre And I Replaced The Fusible Links Coming From The Firewall For Ignition And The Truck Will Turn Over But I...
matt_522000
97 Ford Taurus, Power Steering
160,000 Plus Miles Trouble Started With Ps Fluid Leaking From Clamps, Replaced Clamps And Hose, Then The Hose Kept Blowing Off And All...
Netter
VALVE COVER GASKET REPLACEMENT
I Have A 1998 Cadillac Catera That Is Leaking Oil Slightly From The Valve Cover Gaskets. The Dealer Quoted Me A Price Of $595 To Replace...
RICHARD LAPA
Radiator Fan
My Radiator Fan Has Stop Running Which Is Causing My Car To Run Hot. I Was Told By Somebody That If The Fan Is Burned Out That The Fan...
vaj2a
Rough Rumnning
My Catalytic Converter Plugged Up And It Was Knocked Out And The Sensors Were Replaced. Will I Have To Totally Replace The Catalytic...
rknight
ByPass Filter For 1994 Camry
1994 Toyota Camry, 125,000 Miles. Does The 1994 4 Cylinder Engine Have In And Out Oil Supply Ports? On My Ford F250 Diesel There Are...
thehut
Grand Am Stalls
I Have A 97 Ga With 2.4l Engine With 165k Miles. In The Spring Or Fall When The Temperature Changes, My Car Stalls When You Come To A Stop...
clubberlang
Starter Removal For My 93 S10 Blazer
After Removing The Two Bolts, There Doesn't Seem To Be Enough Room To Move The Starter Back Far Enough To Be Able To Drop It Down. Do I...
nstrub
CHEVROLET BLAZER
1991 Toyota Camry Dash Light Coming On While Driving,
1991 Toyota Camry 245,000 Miles. Driving Down The Road I Noticed The Brake Light, Battery Light And The Lights Light On My Dash All Came On...
jangstew
Wont Run
Ihave A 2000 Pontiac Grand-am Drove It Home Went Out The Next Day Tried To Start It It Backfired And Hasnt Stated Since.I Replaced Ignition...
buckcocoa
WON'T START 1994 FORD RANGER - V6 - 5 SPD
For The Last Three Weeks - I Had Difficulty Getting It Started - I Could Repeatedly Turn The Ignition & It Would Eventually Start. Now, It...
KIMZEM
2001 Honda Civic LX Sedan
I Have A 2001 Honda Civic Lx Sedan With 69000 Miles And Have Just Started Noticing A Squeaking Sound Coming From The Rear Passenger Side. I...
rickdebbie
Replacing Alternator - Rip Off?
I Had My Alternator Replaced Recently - But When I Picked Up My Car All The Radio Stations Were Still In Place. Shouldn't My Radio Settings...
allengmbls
1981 Corvette
My Oil Pan Is Mangled Ihave Installed A High Volume Pump And The Sump Screen Doesn't Fit Because Of The Strange Baffles In The Oil Pan. Can...
rwilson
1981
CHEVROLET CORVETTE
Fuse Box And Wire Harness 98 Escort
A Month Ago My Running Lights Went Out On My 98 Escort 80,000 Miles. The Dealer Said It Had Burnt Wires And Needed A New Wire Harness. $1000...
ktinspired
2000 Lincoln Ls Missing And Emissions
I Have A 2000 Lincoln Ls 3.9 Ltr. And It Started Missing Real Bad And I Noticed A Raw Smell Like The Catalytic Converters Were Going Bad...
Nathan
LINCOLN LS
Wont Start After 3 Days Of Sluggish Starting(like Bad...
[/b] I Have A 1993 Ford Aerostar Van, 130k Miles. Runs Good. But A Few Days Ago Wouldnt Crank, Before Thant 3 Days Before Cranking Was...
ramsxx
FORD AEROSTAR
High Oil Pressure Reading
Normal Oil Pressure Reading At Start-up, Then Pegs Out When I Accelerate
sirchillwill
Mercury Tracer 1996 127500miles
My Car Started To Run Like It Was Missing. So I Checked The Spark Plugs And Either #1 Or #4 Cylinder Was Wet Around The End Of The Spark...
cooperjody
MERCURY TRACER
1988 Buick Skylark 3.0 Litre
This Car Has Just Been Returned To Service After Sitting For A Bit. I Replaced Transmission And Timing Chain Cover, Oil Pump, Timing...
rugruv
BUICK SKYLARK
2002 Sienna Idles Very Low
Got A 2002 Toyota Sienna, About 60000 Miles. Once In A While, I Would Start My Van And It Would Start Off And Idle Very Low And The Engine...
gramos2000
TOYOTA SIENNA
20153
20154
20155
