Cruise Control
I Have A 1986 Jaguar Xj6 With 135k Miles And The Cruise Control Doesn't Work What Are Soem Things I Can Do To Help That?
andrew89
JAGUAR XJ6
Nissan Pickup Won't Start
My 1994 Nissan Pickup With 134,000 Miles And Standard Transmission Does Nothing When I Try To Start It. I Have Replaced The Starter Twice (...
swilson
NISSAN TRUCK
Neon Running ROUGH!
I Have A 95 Dodge Neon Two Years Ago I Replaced The Head Gasket, Timing Belt, Water Pump And The Car Has Been Fine Until A Few Months Ago...
buckeyesuave
Seat Belt Warning Light On
The Seat Belt Light Is Going Off But The Seat Belt Is Properly Locked Into Position And The Automatic Seat Belt Is All The Way Back Where It...
forrest52
1994 Hyundai Sonota V6 Timing Belt
My Timing Belt Broke While I Was Driving, What Is The Process To Find Tdc And Line Up The Cyl Heads, The Manual I Have Only Covers...
daddymancrandall
HYUNDAI OTHER
Brake Lights Wont Go Out
Hi My Wife Has A 2002 Peugeot 206 1.4 Automatic. The Brake Lights Are Permanently On When The Ignition Is Switched On.I Think The Problem...
wade h
Ball Joint Replacement Ford Ranger 4wd 2001 3.0 L
What's Is The Procedure To Change The Lower Ball Joints On A Ford Ranger 4wd 2001. Thank You, Bill
renegade343
Charging Probs 87 Tbird LX
Heeeeeeelp! I Have An 87 Tbird Lx With 5.0 Litre Efi The Instrument Cluster Is Digital. First Car Wouldn't Start Battery Dead. Replaced...
Sleepstalker
Fan Clutch/air Con
I Recently Had My Airconditioning Checked On My 2001 Toyota 4 Runner Because It Didn't Feel Like It Was Cooling Very Well Once The Day Got...
dkrawczyk
Window Washer Resservior Replacement
'03 Sunfire Slx, Has A Leak In The Washer Fluid Tank, Is It Very Hard To Replace The Tank? I Havn't Looked Into It But It Is Located Under...
Eric
E-brake Handle Pulled Out Cant Get It Back In
I Just Got An 1987 Yota Pickup With The 22r In It And The Damn Thing Is Not In Too Good Of Shape But Here My Prob. I Was Trying To Get The E...
the_rookie87
TOYOTA PICKUP
Fuel Pump???
2001 Jeep Grand Cherokee - I Am Having Problems Starting My Jeep. When I Try To Start The Engine The First Time, It Will Never Start. Then...
josh smith
How To Get The Rotors Off?
Hello, Can Someone Please Help Me I Have A 2000 Toyota Camry 4 Cylinder W/68,000 Miles And I'm Having My Brakes Done But I Don't Know...
cheesey
Blew My Battery!!!
My Starter Had Recently Been Going Out, I Even Had A Complete Power Loss Before I Began To Change The Starter. I R/r The Starter And...
2001montecarloLS
1984 Trans Am
I Have A 1984 Trans Am With A 305 Engine It Has 65,000 Miles On It. One Day I Was Going Up A Hill Like 35 Miles An Hour And It Should Have...
Blake1705
1984
84 Lincoln Mark VIII Stalls
Hello, I Just Bought My Car And Did A Basic Tune-up And Noticed Even Afterward That It Will Sometimes Stall. But Only When Almost...
swiftnomad
1984
LINCOLN MARK VI
Check Engine Light
I Have A 2002 Gt Celica With 80,000miles, At High Rpm The Check Engine Light Came On While On 4th Gear, When I Shifted To 5th Gear, The...
giovanni
TOYOTA CELICA
Check Engine Light
I Have A 2002 Gt Celica, At High Rpm The Check Engine Light Came On While On 4th Gear, When I Shifted To 5th Gear, The Check Engine Light...
giovanni
TOYOTA CELICA
2002 Tahoe Heater/AC Fan Switch
I Have A 2002 Tahoe Ls 4wd. It Has 33,000 Miles On It. The Heater/ac Control Switch Does Not Activate The Fan In The #1 And #2 Setting. It...
a68rs
1999 Chevrolet RV
Due To Illness, My Rv Has Sat Idle For A Year. I Tried To Start It And It Started But I Quickly Turned It Off. Is There Anything Special I...
guynsusan
2003 Nissan Sentra Grinds When Starting
Hi Please Hep My Car Grindes When I Start It But Not All The Time Do You Know What It May Be I Called Around But Noone Can Tell Me Over The...
michellejm101
Disable Abs Light
Hello, I Have A 94 Honda Accord, 200+ Thousands Miles Which Runs And Looks Great. Have Had The Car About 9 Years With An Abs Malfunction...
zliquid
Brake Light Stays On
We Have A 1988 Dodge Ramcharger And We Have Noticed That The Brake Lights Like To Stay On When You First Start It Up, And After It Goes Off...
Whitewolff
VW Code: Idle Adaptation At Limit
1996 Vw Jetta, 2.0 L, 295,000 Code Reader Says P1582. For A Vw, That Code Means "idle Adaptation At Limit". What The Heck Does That...
benny haha
White Smoke Coming From Exhaust
In The Last Week Or So I Have Noticed That I Have White Smoke Coming From The Exhaust Of My 1994 Chrysler Lebaron Gtc. It Does Not Happen...
taztornado98
CHRYSLER OTHER
20148
20149
20150
