FAILED SMOG INSPECTION
Hello I Have A 97 Ford Taurus 3. Ol. 151000 Miles I Recently Took My Car To Get Smogged, I Passed Everything But The Funtional Test. It...
SWIPERTHEFOX22
"Power Stering Pump"
Hi Folks. My 1998 Ford Windstar Mileage: 199.998 Has Had A Problem With The Steering Pump. I Have Replaced The Pump Twice And The Steering...
papo
Chevy Suburban
I Have A 1995 Chevy Suburban, About 2 Months Ago It Started With A Problem. When I Am Going Under 20 Miles It Seems Like It Wants To Turn...
juanmanuel
98 Windstar - Headlights Not Working Help!!
I Haven't Been Driving My Car Because I Hurt My Ankle And My Brother Has Been Driving It Once In Awhile. So One Night He Went To Go...
jdipier2
P0045
I Have A 1998 Dodge Stratus V6 130,000 Miles. The Check Engine Light Came On And Threw A Code P0045. But I Cannot Find Any Def. For Codes...
jeffrohotrod
DODGE STRATUS
IGNITION COILS
Where Is The Ignition Coils Located On A 2001 Toyota Rav4, 4 Cylinder
Robertb
TOYOTA RAV4
Toyota 4runner 1995 Blown Head Gasket
1995 4runner, 2wd, 220,000 Miles. I Bought It 8 Months Ago With 200,000 On It From A Donation Yard Where You Pick Out The Car You Want...
J WILLIAMSON
AC Water Leaking Into Passenger Compartment
I Have A 1990 Mazda Miata With 112000 Miles On It. When I Run The Ac After A While The Lower Vents Around The Blower Motor Fill Up With...
Green Machine
MAZDA MIATA
My 1999 Dodge Neon Has 85,000 Miles
My 1999 Dodge Neon Has 85,000 Miles And The Dome Light Won't Go Off And The Door Adjar Light Stays On Yet All The Doors Are Firmly Shut How...
bustercfp
1990 Honda Accord LX Clutch Problems
I Recently Replaced My Select Cable After Having The Clutch R&r'd Even Though I Knew That Wasn't The Problem. Anyway All Of A Sudden I No...
dmag269
VACUM
How Do I Do A Vacum Check On My 1998 Chev Tahoe With A 5.7 V8 Vorted Engine? Where Do I Scew In The Test Gauge? What Should The Vacum Be?
struxgl
CHEVROLET OTHER
Fuel Pump Wont Turn On
I Had Recieved A 1987 Chevy Surban. I Had To Repair The Fuel Tank Because It Had A Leak. I Did Get That Fixed. But I Put Everying All Back...
wfd741
CHEVROLET OTHER
Battery Has A Slow Drain.
I Have A 2002 Yukon Xl With 78,000 Miles. I Have Been Having Problems With The Battery Going Dead After Truck Sits For 4-5 Days. Took...
aqhill
1986 Mercury Sable Steering Knuckle--30536miles
How Do I Remove The Steering Knuckle So I Can Replace The Wheel Bearing/hub Assembly On The Right Side
fire lt
MERCURY SABLE
Burned Up Over Electrical Problems/1988 F150
1988 Ford F150 Lariat 4wd.223000 Kms. This Truck Has Been Very Good Up Until Recently. For What Ever Reason The Battery Started Going...
Doug V
Car Rust
I Drive A 1990 Honda Accord With About 145,000 Miles. Some Rust Has Started To Develop Above The Rear Wheels And On Some Other Areas Of The...
czy4heels
97 Voyager 3.0
I Have A 97 Plymouth Voyager And I Had The Tranny Rebuilt In June Of 05 The Van Has 122500 Miles On It And It Just Recently Started Acting...
loucifer30
PLYMOUTH VOYAGER
1995 Escort Makes Me Pass Out (almost)
Ford Escort Lx 1995 126000 Miles The Car Was Leaking, What Seemed To Me To Be Coolent, But Didn't Fix It. Yes, Typical Female Who...
anootsa
2000 Hondic Civiv 75000 Miler 5 Spd It Wont Start
Honda Wont Start Its Totally Dead. Fuel Good Battery Good Fuel Pump Good. I Will Disconect The Battery And Then Reconected A Few Minutes...
red100
HONDA OTHER
Clutch
I Have A 96 Civic With 245,000 Miles, It Has A Manual Transmission.I Just Had A New Clutch Installed 3 Months Ago. I Have Had No Problems...
mfpicon
2003 Dodge Neon - Noise While Driving - Left Side
2003 Dodge Neon - 80,000 Miles - My Car Is Making A "whirring" Noise When Driving At 20 Mph Or Faster. It Seems To Be Coming From The Left (...
chaberly
2000 Durango - AC Clutch Wiring Issue
I Have A 2000 Durango With 5.2l V8. The Return Side Of The Ac Clutch (black Wire) Shows Very High Resistance To Ground (and The Clutch Won'...
jdearden
White Foam In The Oil Spout
I Have A 1998 Ford F150 Triton V8 With 165,000 Miles On It, I Take Very Good Care Of My Truck And It Runs Great. My Question Is That When...
Charlie2949
Shifter Won't Move Into Gear
I Have A 1994 Honda Del Sol With 150k And Have A Problem Shifting Onto Gear When First Starting Up. I Have Noticed This For About A Month....
rickwood
HONDA DEL SOL
1993 Manual Transmission Problem
I Have A 1993 Honda Accord, Lx W/5 Spd Manual Transm. After Driving For About 30 Minutes The 2nd Gear Grinds Whenever I Shift Into It (...
bjggross
19865
19866
19867
20251
