Occasional Starting Problems
LRYMCD
  • FORD PROBE
1990, Ford Probe, 2.2L, nonturbo, 4 C, 354000 miles.
Most of the time the car starts up fine. But at times the engine will tune slowly like it will not start. Simular to having a weak battery. When it does start this way, I will turn the car off and it will restart fine. The lights, horn and blinkers work fine.
The battery and starter are new. Problem existed before replacing both.
Sunday, January 14th, 2007 AT 11:13 PM
MATHIASO
  • 1,209 POSTS
Check battery cables and connectors.
Are you using the right oil viscosity, it may be cold where you are.
Monday, January 15th, 2007 AT 12:01 AM
SERVICE WRITER
  • 9,123 POSTS
There is a tsb Ref # 91-16-6 that refers to a wiring problem in front of the radiator, water intrusion into the engine harness causing various problems including a no start. It may or may not apply to you.
Monday, January 15th, 2007 AT 4:35 AM
DJHAFNER
  • 8 POSTS
Don't know a whole heck of a lot about cars, but I just wanted to say congrats on 354,000 miles!
I'm guessing you change the oil every 3,000 miles without missing a beat?
Monday, January 15th, 2007 AT 7:38 PM
SERVICE WRITER
  • 9,123 POSTS
Amazing what you can get out of cars if you want to!
Monday, January 15th, 2007 AT 7:49 PM
