Thursday, June 12th, 2008 AT 3:58 PM
I have a 96 Ram with a 360 auto trans. At times, warm or cold, when I take my foot off the gas, it stalls. The RPM's drop instantly like I just turned off the key. It will start back up and at times it will stall back out when I take my foot off the gas again and others it will run just fine. I have had my trans rebuilt, don't know if that has anything to do with it. I also notice at times the RPM's will drop to around 200 and them bounce back up to normal idle rpm. Most of the time the RPM's will slowly drop to normal idle speed. I have had it in the shop where they checked everything and found a dirty throttle position sensor that they cleaned off. All pressures, and readings were fine.
