How to Test and Replace a Car Fuse
fuse test
 This guide demonstrates how to locate and test the various car electrical fuses that protect particular electrical system accessories. When testing a fuse, there are two aspects to consider. First, the integrity of the fuse is subject to failure. The second is to confirm electrical power is present at the fuse. The second is to test for electrical power at the fuse, if the sub-system that powers the circuit is not working i.e. a bad power relay, maxi or fusible link the fuse will not have power and the accessory will not work.
What goes wrong?
Again, with the key still in the on position start checking for power at all fuses, ground the test light and touch the point to the top metal tangs on both sides of the fuse. A fuse with power on just one side is blown and needs replacement. Note: Some fuses will not have power on either side due to nonuse of the fuse at the time. When testing lighting system fuses etc its best to have the system in question turned to the on position.
fuse testing
Once you have found the bad fuse remove the unit using your fingers or a small pair of pliers. Sometimes there will be a tool located inside the fuse panel to help with the removal. This is what a bad fuse looks like compared to a good one. Replace failed fuses with proper amp rating, not doing so can result in electrical system damage. Also, fuses can cause intermittent open circuits by becoming loose or corroded in the fuse holder, make sure fuse is held securely and free from dirt or corrosion.
popped fuse
Watch the Video!
Please watch this video of the job being done, then continue down the guide to glean additional helpful information.
Good to Know
 If the fuse blows when replaced the protected circuit is shorted to ground via either the wire itself or the accessory has failed internally, in either case a repair is necessary to resume normal fuse operation. If no power is detected at the fuse or panel (either side of the all fuses) use a wiring schematic to trace the power source, usually a main power relay, maxi-fuse or fusible link has failed.
Questions?
Our certified technicians are ready to answer fuse test questions for free. We hope you saved money and learned from this guide. We are creating a full set of car repair guides. Please subscribe to our 2CarPros YouTube channel and check back often for new videos which are uploaded regularly.
Repair Safety Notice: This guide is provided for general informational and educational purposes only. Vehicle repairs can involve risk of injury, property damage, or vehicle damage. Always follow proper safety procedures, use the correct tools, support the vehicle securely when raised, and consult a qualified automotive repair professional if you are unsure about any step.
