Mechanics
VAN WONT STAY RUNING
2003 Honda Odyssey • 159,000 miles
My van would not start up at all, they said it might be the fuel pump and I got it replaced, still not working. I replaced the fuel regulator, still not working I change 6 spark plugs. It will start up but it would die a second after now could the coil be the problem question
Matdanmow
May 9, 2013.
Only diagnostics test woul tell you what is wrong.
Is the Malfunction Indicator Light showing and have you checked for trouble codes?
Are you able to keep the engine running with slight throttle pressure?
Can it be restarted each time it stalls?
KHLow2008
May 10, 2013.
Matdanmow. Did you fix the problem you had with your van I have same problem with my van what was wrong?
Revilo937
Jun 4, 2014.
Non starting can be due to various reasons so you start with the basics like checking to see what is missing and find out if any trouble codes are present.
AD
KHLow2008
Sep 22, 2014.
AD
