Mechanics
CHECK ENGINE LIGHT
2003 Mazda Protege
Computer problem
2003 Mazda Protege 4 cyl Front Wheel Drive Automatic 70000 miles
The check engine light came on for no apparent reason. Engine fluids are all good. No overheating or other visible or audible mechanical problems. Drives fine. Had belts and timing chain/belt replaced about a month ago and the oil changed as well.
Timothy14
May 24, 2008.
Hi there,
The ECU has logged a fault code form the input of an engine management sensor, you will have to get a scan retrieve the code, your tech will use this code to determine where the fault lies.
Mark (mhpautos)
Mhpautos
May 24, 2008.
