Mechanics
COOLANT LEAK
1997 Jeep Cherokee
Engine Cooling problem
1997 Jeep Cherokee 6 cyl Four Wheel Drive Automatic 110000 miles
I have a leak from my engine. The leak is above where the hose connects to the engine from the radiator. When I pour water into the radiator and look underneath I see water coming from the area about 2-3 inches above the hose connection on the engine. What would this be? How can I fix it or is it something to do with the engine? I have already replaced the radiator and all the hoses are in good shape so I know it is coming from the engine.
Mangum
November 4, 2009.
Is it the upper or lower radiator hose? Could be the thermostat housing gasket that has failed and leaking coolant. It is located at the end of the radiator hose near engine.
It is the lower radiator hose but it is leaking at the end connected at the engine. The hose is not leaking but when you look up from underneath you can see fluid coming from above the hose connection in the engine. Doeas that make sense. What is the lower radiator hose connected to at the engine the water pump?
Mangum
Nov 4, 2009.
It is the lower radiator hose but it is leaking at the end connected at the engine. The hose is not leaking but when you look up from underneath you can see fluid coming from above the hose connection in the engine. Does that make sense. What is the lower radiator hose connected to at the engine the water pump?
Mangum
Nov 4, 2009.
I believe your upper radiator hose has the thermostat while the bottom goes to the water pump. So since the lower radiator hose is where the problem is, it may actually be leaking from the water pump's weep holes. They will do this when they begin to fail.
AD
Thanks for you help. It is the water pump and I am changing it this weekend along with a tune-up and oil change.
Mangum
Nov 6, 2009.
AD
