Honda Accord Repair Question
Topics covered: Radiator, Transmission, Oil leak.
Asked on March 26, 2006
Oil leak
I have a 1994 honda accord auto transmission recentley it has got an oil leak i can see the oil leak near the bottom end of radiator like i can can see the oil leak from the housepipe going out from radiator by seeing the colour of ythe oil i can say it is transmission oil could u explain me about the transmission cooling system and weather the transmission oil passes through the radiator for cooling.
Answer
Replied on March 26, 2006
That is affirmative. The oil from the tranny is cooled in the radiator. I would check where the leak is coming from and then if it is from the core or the radiator itself, I would replace it. Don't mess with anything else. They can run around 80 new. You could also check to see if one of the connections has loosened up and retighten it.
