AC Recharge
1991 FORD TEMPO
50,000 MILES • 2.3L • 4 CYL • 2WD • AUTOMATIC
MONTELL2050
I need to find a Way to recharge my ac unit I tried buying it from Nap and when I got it it didn't fit on there right so I went back and was told it was a special piece I needed in order to recharge it if you could try and giving me some infor or some help that would be nice.
Aug 15, 2014 at 7:38 PM
  • CAR REPAIR CONTRIBUTOR
  • 54,350 POSTS
Yep we have some great guides that will show you everything you need to know about charging the air conditioner.
https://www.2carpros.com/articles/air-conditioner-how-to-add-freon
and
https://www.2carpros.com/articles/re-charge-an-air-conditioner-system
and
and
https://www.2carpros.com/articles/how-a-car-air-conditioner-works
Cheers, Ken
Jul 26, 2017 at 7:37 PM
PROCTOR.ANDREW
Air Conditioning problem
1994 Ford Tempo
I'm trying to recharge the AC in a 1994 Ford Tempo. I can't seem to make a connection between, what I think is the, recharge port. It tries to connect but will just spew refrigerant everywhere. Any ideas? Am I using the right port. It's at the very front under the hood. HELP! I've been without AC for almost seven years and can't bear another Texas summer!
Jul 26, 2017 at 7:38 PM (Merged)
The low pressure service port is located in the low pressure line from the compressor.
FORD:
1994 TEMPO
LINCOLN-MERCURY:
1994 TOPAZ
ISSUE:
The service couplers originally supplied with most of the Rotunda R-134a A/C Service Centers, models 078-00850 and 176-00001, were too long to access the suction port on the subject vehicles with the R-134a system.
ACTION:
New shorter Retrofit High and Low Side Quick Disconnect Couplers were provided at no cost to Rotunda customers. These couplers should be used as a permanent replacement. Access to the suction port is achieved with these Low Side Quick Disconnect Couplers.
Additional pairs of these R-134a Low Side Quick Disconnect Couplers, for use on these or other brands of R-134a Service Equipment are available through Rotunda by ordering item # 176-R0036.
OTHER APPLICABLE ARTICLES: NONE
WARRANTY STATUS: INFORMATION ONLY
OASIS CODES: 208000
FIXITMR
  • 9,990 POSTS
the freon low side port is up by firewall left side by/on canister in ac line. it's a little difficult to get to on 4cyl.
GEORGE WHITELOCK
  • 6 POSTS
The air conditioner only blows out of the floor as well as the defrost. Nothing coming out of the dash vents when either air conditioner or panel vent button is pushed. I changed the dash control, no different. Not a vacuum problem from motor, plastic hose is okay. Both heat and cold air okay.
HMAC300
  • 48,601 POSTS
check for a vacuum line disconnected or the vacuum motor may be sticking/broken or broken door. see picture.
GEORGE WHITELOCK
  • 6 POSTS
okay will do. I will check yellow hose with vacuum pump and report findings. Many thanks
George W.
GEORGE WHITELOCK
  • 6 POSTS
Apparently the dash control was a real problem according to a senior FORD tech anyone have a new old stock one with rear window defrost?
HMAC300
  • 48,601 POSTS
you'll have to try a junkyard for that you can go to a ford dealer and they can look up part number and check nationwide if someone has it you contact that dealer and make a deal cause they can't return it.
