1994 Ford Ranger Repair Question
Topics covered: Radiator, Thermostat, Engine.
Asked on May 27, 2008
1994 Ford Ranger overheating
engine overheated from leaking hose. Added stop leak,coudn't find the exact location at first. Worked for a couple of days, then overheated again. Let cool down for 5 min., trickled water into radiator to cool down and fill. Changed hose, ran fine for a couple of months. started to run warmer than usual,(midrange), no signs of leaks. Topped of system every week or so. Temp spiked at top of range, (freeway at night, 70 degrees outside), then dropped to midrange. Roughly 10 miles of freeway driving. Drove another 10 miles,(freeway), gauge fluctuating every 10-15 seconds from top of range to lower 1/3 range mark. Changed thermostat, flushed radiator and system. No change. Changed other hose, same thing. Changed pump, tested thermostat again. Gauge spikes to 3/4 range within 2 minutes, then drops to 1/3 for 5-10 seconds, then spikes again in 5-10 seconds. Ran with garden hose in radiator neck, same thing. When cap is off, gushes from neck after 45 seconds, not a steady overflow. Upper hose runs hot as well, lower hose stays cool. Suspected bad heads or block from first overheat. Had both checked. 1 head near warp limit and corrected. Now overheats within 1 minute, the rest is the the same. No problems at all before this mess. Next step is dynamite!
Answer
Replied on May 27, 2008
upper hose is hot. lower is cool?
suspect faulty thermostat, bad water pump, restricted radiator, trying having it rodded out. or take it off and apply radiator flush to it and keep running it through.
