Engine will not crank over?
2001 FORD MUSTANG
65,000 MILES • 4.6L • V8 • RWD • MANUAL
SHAYNE CANADY
Car was fine, then it suddenly would not start. The battery is fine, no clicking, but it will not crank at all. Unfortunately, this happened a couple days before major neck surgery, so now it has been sitting idle in the garage for seven months. Help?? I tried the starter relay, but that is not it. I cannot spend a lot on replacement parts only to find they are not the issue.
May 10, 2016 at 9:42 AM
HMAC300
  • CAR REPAIR CONTRIBUTOR
  • 48,601 POSTS
make sure the battery is fully charged and in good condition including a load test. make sure terminal ends are clean then try resetting security system if no manual look online for your car on how to reset it.
May 10, 2016 at 12:04 PM
RENEE L
  • 1,260 POSTS
Here is a link to an informative article from this site with step by step instructions and pictures on what to check for when your vehicle will not crank over.
I hope this helps you. Thank you for visiting 2CarPros.com.
https://www.2carpros.com/articles/car-engine-will-not-crank-over
May 10, 2016 at 12:53 PM
BOOPERIII
replaced the starter cost me $139.00
Nov 13, 2019 at 6:54 PM
COMM7_911
  • 6 POSTS
While driving, my car chugged twice then died. I am unable to restart the car, the engine won't even turn over. We have checked the battery and starter, both needed replacement. All dash lights and headlights work, and we are getting power to the starter (tested with a volt meter). The battery terminals are clean and we have tested the relay and checked the fuses. Suggestions? Does this sound like an electrical or engine problem?
Nov 13, 2019 at 6:54 PM (Merged)
wont start, engine will not turn over
This guide will help us get started.
If it cranks over the starter has done its job. Try carb cleaner in the throttle body-did it start and stall? If so check the fuel pressure and comeback with the readings
COMM7_911
  • 6 POSTS
No, it doesnt turn over at all. I turn the key and get "click"... thats it.
Earlier you said you're getting power at the starter-have a helper put key to start position and bang on the starter if it kicks and engages the engine -defective starter.
COMM7_911
  • 6 POSTS
We've tried that, with the old starter and the brand new one (installed last night), no luck. Thanks for your prompt answers. Much quicker than I had anticipated!!
You might want to triple check the battery condition and its connection make sure its clean and tighten, also at the starter relay and starter
BULLITT1939
  • 37 POSTS
First problem I had was a battery issue. I fixed that and then the car turns a second then locks up. We have changed the starter also, but it is doing the same thing. I have never had a motor do this. My car is the Bullitt model.
COMM7_911
  • 6 POSTS
We can check those off the list, too. Unfortunately we've previously had no luck with those suggestions either
CJ MEDEVAC
  • 11,004 POSTS
Can you turn the engine 2 to 2-1/2 full revolutions, in its normal direction with the key off?
Using a ratchet or a wrench on the harmonic balancer bolt? (Picture of my 1977 Jeep CJ-5 6 cylinder below).
Other than a mechanical issue or failure, coolant in a cylinder (head gasket) cannot be compressed and will show your symptoms.
Removing the plugs and turning it might verify this possibility.
Any recent abnormal issues happen prior to this?
The Medic
Okay find the transmission range sensor left rear side of transmission check for power at the red and light blue wire-nothing there check fuse no.6 20amp at central junction box behind dash left of steering column. Then report back
BULLITT1939
  • 37 POSTS
I will give that a try in the morning. Car sat for a while, which is why the battery was dead. Hooked the jump box to it and it started. Though it did do this at this point. Possible symptoms of a starter going back so we changed it. When you turn the key it turns over very short and then whole engine jumps like it would be locking up. Prior to this no real issues. Use to be my daily driver.
COMM7_911
  • 6 POSTS
I am at work now, will check when I get home. Thanks again!
Nov 13, 2019 at 6:55 PM (Merged)
CJ MEDEVAC
  • 11,004 POSTS
Keep us posted.
The Medic
COMM7_911
  • 6 POSTS
They are both ok
FISHFIGHTER
  • 5 POSTS
This is number 5 mustang with the same problem.Did you get it fixed?What was it?
JOHNSONH84
occasionally car wont crank over. ive got power to everything. when i turn the key nothing happens. after a few minutes it usually starts right up. car runs great and has never given me any problems until now. im not sure if ive got a lose wire on the starter? if there is a swith on the clutch pedal that may be going bad since the clutch pedal has to be depressed for the car to start? ignition switch going bad? any ideas???? please help!!!
FISHFIGHTER
  • 5 POSTS
Did you ever find out what is happening to your car?I happen to have the same problem
JOHNSONH84
havent gotten an answer. just did it again the other day...i think its the ignition switch though. if it fails to crank and i jostle the key around it starts up. must have tumblers or a contact swith going bad. let me know if you find out anything....
FISHFIGHTER
  • 5 POSTS
Does it not turn over just when it is hot?If so,It could be the starter.To find out if that is the problem,you will need two people to check and a 12 volt meter.With one person in the car and one under,set up the meter to the + on the starter and ground the other side.At that point,have the person in the car turn on the key as in starting the car.If you read 12 volts and the starter is not trurning out,your starter is bad.If no voltage,it could be the starter relay or in my case the clutch safety relay switch.
CARBONKID24
i have a 2001 one mustang 6 cyl, as i was driving my car it started to chug and died on me as i was driving the gauges stayed stucked on the postions the were on, i then pulled over to the side of the road turned off the car and tried to turn it on again but nothing happen it turned over but the car wasn't turning on. i put the key in and turn it without turning it on the service engin soon light is on as well as the battery light is on.
Check the fuel pressure if its within specs and the alternator if its putting out, could also be a defective ignition switch-start here and then let us know-
CARBONKID24
it turns out my fuel pump isnt working
LILMAMA3517
Engine problem
2001 Ford Mustang V8 Wheel Drive Type unknown Manual 50000 miles
My car turns over then shuts off. you have to keep your foot on the gas to keep it running. I am having trouble locating the idle to turn it up. Can you help me?
MUSTANG87
  • 261 POSTS
hello, you cannot adjust idle like the old cars on the mustang.u will need to buy a new idle control valve.not hard to install.its a round the throtle body.if u dont know what it looks like just go to www.kragen.com and put ur car yrs etc then look for idle control valve and a picture will will show you what it looks like.
LEESTER
Hello, please help/advise.
2004 Ford Mustang convertible / V6 / 3.6L / automatic / 140,000 miles / new battery / only year old spark plugs / distributor coil.
Car is garage-parked . . . not a daily driver . . . but crank & run it every weekend.
We just had unusually cold Houston weather (12 degrees) . . . and I did notice the negative/ground cable on the battery was "loose"/not tight . . . could pull it off of the negative terminal by hand.
Symptoms: Turn the ignition and the car attempts to crank . . . turning over strongly (not battery) . . . but will not fire up/run . . . headlights come on / radio plays.
OK . . . so took off both battery cables / cleaned them / replaced & tightened them snugly . . . same results . . . turns over strongly but will not fire up/run.
Noticed that the "THEFT" light on dashboard is blinking weirdly/erratically . . . and hearing something sounding like ??? 4x times mechanical repetitive sound (like behind the radio ???) when sitting in car attempting to crank immediately after turning engine over ???
Put jumper cables on . . . same results . . . turns over (even stronger now) . . . but will not fire up/run.
1. Fuel Supply (frozen gas line ??? fuel pump ??? fuel filter ???
2. Fire (Spark Plugs ??? Spark Plug Cables ??? Distributor Coil ??? My guess & will start here.
3. Engine Compression ???
Feb 20, 2021 at 10:06 PM
Good morning,
Do you hear the fuel pump run when you turn the key to the on position?
When you crank the engine, does the tachometer show a little RPM?
Yes, I would do a compression test to be sure the engine is good.
Feb 25, 2021 at 8:22 AM
Okay, since the original question here was for another issue, please start a new question and we will be glad to help you.
Feb 25, 2021 at 10:49 AM
