Mechanics
NO HEAT
2003 Ford Explorer
Heater problem
2003 Ford Explorer 6 cyl Four Wheel Drive Automatic 89000 miles
i have a2003 exploer I turn the heat on and the fan I hear a flapping noise in the heater box (manual control) is it possible to remove the dashboard to get to the heater assy to repair the door flap
Passatvr6
December 10, 2009.
Actually, you should be able to access the vent door from under the dash. You may have to remove the glove box.
NOTE: Because your vehicle has an airbag, I would recommend disconnecting the battery for at least 30 minutes prior to starting any repairs. Air bags can deploy if not handled correctly.
AD
