2CarPros - Car Questions & Answers
1999 Ford Explorer Repair Question
Topics covered: Fuel pressure, Fuel pump, Spark.
Asked on June 18, 2010
1999 Ford Explorer It just Died... and won't start
Engine Mechanical problem
1999 Ford Explorer 6 cyl Four Wheel Drive Automatic 120000 miles
Ok, my wife was driving my 99 for explorer and it just died in the middle of the road. Since then we have not been able to get it started. occasionally it will sound like it is going to turn over, but dies immediately. I disconnected the fuel filter and tested the fuel pump, it was good. Then we check; in no particular order; The Coil (which fired great), the injectors (all fine), The plugs, the plug wires, fuel lines, Inertia switch, the throttle body position switch.... I then replaced the O2 sensor on the transmission, and the Fuel Pressure Regulator. The fuel is making it to the fuel rail, and the computer isn't throwing and error codes,
I am out of ideas... Please Help
Avatar Asked by Jimbomm
Answer
Replied on June 18, 2010
Check the fuel pressure with a gauge EFI system don't like low pressures
Tiny Answered by rasmataz
68 questions asked
I have replaced the fuel pressure regulator, and the fuel filter, and I "tested" the fuel pump my disconnecting the fuel line at the filter, and turning the ignition. The pump produced what i would call a decent amount of gas.
So, Since i know the regulator and filter are good,
am i right in assuming that the only thing that could cause low presure would be a week or non-functioning fuel pump?
and since my pump is definitivly sending gas... i guess my question would be,
Will a week fuel pump completly prevent the vehicle from starting?
(The main reason i am asking this is becuase I don't want to shell out the $75 dollars for a gauge)
Tiny Response from Jimbomm
1 question asked
It might be spitting out fuel but is it 30-65psi as required by specs. Guessing can be costly, also are you getting ignition spark and are the injectors pulsing??
68 questions asked
Replied on June 24, 2010
As i say, i do not have a gauge to check the actual Fuel Pressure. The sparkplugs are firing, and the Injector Coil is Pulsing, I used an Ohm meter to test the injectors themselves, they read at 15 ohms which is within the tolerance range of 11-18 ohms that the "Chilton service manual" says means the injector is functional...
1 question asked
If the sparkplugs are firing then you have a fuel problem or a valve and ignition timing
68 questions asked
