Brake warning light?
ANONYMOUS
  • 2003 FORD EXPLORER
  • 160,143 MILES
Hello I have a 2003 ford explorer. While driving I tapped the brakes to come a stop but the brakes did not stop immediately. I had to press all the way down on the brake pedal for the truck to slowly stop. I pulled over and noticed the brake light on my dash board was on and a dark brown oil like liquid was leaking from my rear passenger tire.
Saturday, December 29th, 2012 AT 5:24 PM
CARADIODOC
  • 33,752 POSTS
You have a rusted steel line or the wheel cylinder blew out. Neither of those are especially expensive or difficult to repair. The exception would be if the rear brake was worn out and grinding metal-on-metal and you ignored it. Be aware though that as a result of pressing the brake pedal further than normal, that can damage it on any vehicle more than about a year or two old, so don't be surprised if after the repairs are completed at the rear, your mechanic has to tell you a new master cylinder is also needed. There's no way for him to know that right away but many shops will warn you ahead of time to prevent surprises later. Even if your master cylinder is okay, some damage may not show up for a few days. When and if it does, it results in a slowly sinking brake pedal when you hold steady pressure on it, and the red warning light will turn on again.
Saturday, December 29th, 2012 AT 8:37 PM
MEP5465
  • 1998 FORD EXPLORER
  • 6 CYL
  • FWD
  • 153,000 MILES
My brake light on the dashboard is on. Does this mean I need to add fluid or does this mean my brakes are going out?
Monday, December 21st, 2020 AT 10:52 AM (Merged)
BUDDYCRAIGG
  • 2,262 POSTS
The light will come on if either one of those problems happen.
If it's full, then you need to have it checked.
You could have a leak, a problem with the master cylinder, the proportioning valve.
Brakes are not something you want to gamble with.
It's one thing to throw your fan belt and be stranded on the side of the road, it's another to run a stop sign and crash into a bus load of nuns, taking kittens to an orphanage.
ABARRY888
  • 7 POSTS
  • 1995 FORD EXPLORER
  • 6 CYL
  • 100,000 MILES
I changed out all the brakes. Shoes, cylinders and pads. I still have a light that says "BRAKES" CAN I GET THE LIGT TO GO OFF? THANKS JAMES
  • 108,269 POSTS
James:
Hi. Have you checked the basic things like the park brake switch, brake fluid level, level switch?
ABARRY888
  • 7 POSTS
Hello.A couple of things. First. It's a 92 ford explorer and it's the "REAR ANTI-LOCK". LIGHT THANKS JAMES
  • 108,269 POSTS
Have you checked the wiring to the sensor?
ABARRY888
  • 7 POSTS
Where is the sensor? And do you know about the neutral safty switch? Truck won't start with key, I have changed the key, the elec. Switch. I checked what I think is the safty switch. 3 wires going to plug on trans. All 3 wires show hot, key on or off, park or reverse
  • 108,269 POSTS
Based on what I could find, you must only have rear ABS. THe sensor is on the differential.
As far as the neutral safety switch, here is a picture of it. Let me know if it is what you are looking at. If it is, there should be power in from one wire, the other two should have power out only when in park or neutral. One is for starting, the other is for the back-up lights.
https://www.2carpros.com/forum/automotive_pictures/249084_5_9.jpg
ABARRY888
  • 7 POSTS
Hello.I find power in, other 2 hot in park, put in drive and the 2 are still hot, . Thank you very much for your help. James
found a sensor on the dif. But seems to have nothing to do with brake lines? Just mounts on top of dif. And seems to go inside it? Thanks
  • 108,269 POSTS
The switch you found in the differential is for the ABS. Make sure the wires are clean and making good contact. If they are, replace the switch.
As far as the neutral safety switch, it sounds bad too.
DAMIANVIGIL69
  • 1994 FORD EXPLORER
  • 6 CYL
  • 4WD
  • 205,407 MILES
Ok here is my problem I have a 1994 ford explorer xlt and it is a old car as you can tell but I was wondering how come everytime I dirve my car the parking break say's its on and when I rev. The car to 3,000 rpms it gose off but then when the car is at idel speed it comes back on so I was just wondering what could be the problem?
  • 108,269 POSTS
Two things. First, make sure the master cylender is full of brake fluid. If it is, check where the park brake is located to determine if the switch is out of adjustment or loose. The switch is located toward the top of the pedal.
Let me know what you find.
ABARRY888
  • 7 POSTS
Well. Turns out the switch has 4 prongs. And is not the problem? Bought new one, pluged it in and held it to the trans. No luck? Gonna take it to a mechanic. Thanks again for your help.
  • 108,269 POSTS
James, Let me know what you find.
ABARRY888
  • 7 POSTS
Well turns out they say the colum shifter is just worn out, when ever I would put in gear I would have to readjust the lever a couple times to get it in gear. Thanks
  • 108,269 POSTS
I'm glad you found the problem. I have to be honest, that isn't a common problem. Regardless, if it is fixed, that is all that matters.
Let us know if you have questions in the future.
