2CarPros - Car Questions & Answers
2003 Dodge Neon Repair Question
Topics covered: Sensor, Crankshaft, Engine.
Asked on September 5, 2010
2003 Dodge Neon Crankshaft positioing sensor
Engine Performance problem
2003 Dodge Neon 4 cyl Two Wheel Drive Automatic
I am trying to replace the crankshaft positioning sensor in my 2003 neon, what is the procedure? Thanks
Avatar Asked by shedances
Answer
Replied on September 5, 2010
REMOVAL - 2.0, 2.4, 2.4L TURBO
Fig.1 Crankshaft Position Sensor Location
http://www.2carpros.com/forum/automotive_pictures/12900_c1_49.jpg
The Crankshaft Position Sensor is in the front of the engine block just under the starter motor.
Disconnect the negative battery cable.
Raise vehicle and support.
On 2.4L SRT-4, remove the lower inner cooler hose from the metal tube.
Fig.2 Structural Collar And Bending Strut - (Automatic Transaxle Equipped)
http://www.2carpros.com/forum/automotive_pictures/12900_c2_42.jpg
Remove the Structural Collar, refer to the Engine, Structural Collar Removal and Installation section.
Unlock and disconnect the electrical connector to the crankshaft position sensor.
Remove the crankshaft position sensor bolt.
Fig.3 Crankshaft Position Sensor - 2.4L Turbo
http://www.2carpros.com/forum/automotive_pictures/12900_c3_18.jpg
Remove the sensor.
INSTALLATION - 2.0, 2.4, 2.4L Turbo
Check O-ring for damage and lubricate the O-ring with engine oil before installing sensor.
Use a twisting motion when installing the sensor.
Install and tighten the crankshaft position sensor bolt and tighten to 9 Nm (80 ±15 in. lbs.) .
Connect and lock the electrical connector to the crankshaft position sensor.
Install the Structural Collar, refer to the Engine, Structural Collar Removal and Installation section.
On 2.4L SRT-4, install the lower inner cooler hose to metal tube and tighten clamp.
Lower vehicle.
Connect the negative battery cable.
http://www.2carpros.com/kpages/auto_repair_manuals_alldata.htm
Tiny Answered by rasmataz
68 questions asked
