Engine has as a rough idle?
1999 CHEVROLET SILVERADO
140,000 MILES • 5.3L • V8 • 4WD • AUTOMATIC
DEMINGSJ
A few days ago I was accelerating to merge onto the freeway and my truck suddenly decelerated while my foot was on the gas. It then returned to normal running. Temperature was fine, oil pressure was fine. Two day later it was still running great in the morning, but by lunch it was a rough idle as soon as it started and then it would shut off. hitting the accelerator made it bog down even worse. Sometimes it would turn over strong, but would not start at all. There are no OBD codes and no lights on the dash. I replaced the pump relay and it did not help. Do you think it is fuel related or am I barking up the wrong tree?
Jul 11, 2017 at 1:38 PM
  • CAR REPAIR CONTRIBUTOR
  • 54,354 POSTS
Yes the fuel pumps go out in these trucks all the time. I have put two in my truck.
Here are some guides and some diagrams (below) to help you get the job done:
and
https://www.2carpros.com/articles/how-to-replace-an-electric-fuel-pump
and
https://youtu.be/Q5MH2gnyFH0
Cheers, Ken
Jul 12, 2017 at 11:04 AM
DEMINGSJ
I changed the fuel filter and it started right up. It ran and drove good for about two miles and then it died and wouldn't start again.
Jul 12, 2017 at 4:48 PM
  • 54,354 POSTS
Yep, it sounds like the fuel pump has gone bad.
Let me know what happens after you replace it.
Best, Ken
Jul 13, 2017 at 11:37 AM
JPSOONER
truck runs fine at low & highway speeds. changed plugs & wires & 2 coils code said were bad. code now says misfiring, but doesnt say which or how many cyls. truck just idles really rough.
Nov 16, 2020 at 11:13 AM (Merged)
Misfires can be caused by worn or fouled spark plugs, a weak spark (weak coil, bad spark plug wire), loss of compression, vacuum leaks, anything that causes an unusually lean fuel mixture (lean misfire), an EGR valve that is stuck open, dirty fuel injectors, low fuel pressure, or even bad fuel.
JOEL MONTGOMERY
I have a 1999, 5.3 Chevrolet Silverado 1500, 135,000 mi. The "check engine soon light" is on and the code is P0303, #3 cylinder miss. Idles rough at about 400 rpm, seems to run fine at normal operating speeds. I checked the coil pack, changed plugs and wires, checked compression, and fuel injectors all good. Checked power to the injector to #3 and it was good. Swapped the coil pack and injector with the #5 cylinder and the code is still the same, #3 cyl miss.
Could this be a computer problem or possibly a lifter problem. I really don't want to get into the engine if I don't have to.
Dumbfounded in NJ
BRIAN 1
  • 1,030 POSTS
check the lower intake manifold for vacuum leaks,this a very common problem on these vehicles.you have all the simptoms of a vacuum leak at the intake.post back with any other questions.
RONNIEFRANKIN
  • 7 POSTS
Went to start it today. It backfired and some smoke came from under the hood. Runs good at a high rpm but fluctuates at an idle. Sometimes it almost shuts off. Thanks for your help.
  • 54,354 POSTS
It sounds like you need a tune up have you installed plugs and wires AC delco? Also is there is check engine light on if so lets run down these guides to see whats going on.
and
MIKETAY
  • 16 POSTS
I have changed dist cap , rotor , sparkplugs(@ 100,000), wires, fuel filter, and cleaned maf sensor. I didn't have codes a first but, then service engine light came on and code said cylinder 5 misfire. I pulled the sparkplug and the electrode was built up with black crusty gunk on one side and white and clean on other side. Plug in cylinder 3 was also built up. I changed the plug (5) and added seafoam cleaner to gas. Local Autozone guys said it could be a clogged injector, bad plug, or I may need to change injector spider. I have run a tank of gas with seafoam and Idle seems to be better at times but not always. It is worse when cold. Acceleration was rough but seems smoother after I cleaned MAF sensor Is there anything I missed? Thanks, Mike
Misfire @ 5 could be the plug/compresssion/injector on that cylinder. Try cleaning out the idle air control valve
MIKETAY
  • 16 POSTS
I found the problem. After checking all sensors. I decided it had to be the intake or headgasket. On teardown I found the plastic intake gasket I replaced at 100,000 miles had warped into a slight arc. After removing the gasket, I could see the o-ring seal had dropped below the #3 & #5 ports which created a vacuum leak and sucked oil into the cylinders. I replaced the intake gaskets with metal gaskets and reassembled. She runs great and does not use any oil. Problem Solved!!!!! Thanks for the help! Mike
