1994 Chevrolet Silverado Repair Question
Asked on April 10, 2010
1994 Chevy Silverado engine idles high (1400) rpm and it sh
Engine Mechanical problem
1994 Chevy Silverado V8 Two Wheel Drive Automatic
engine idles really high 1400 pm and it shifts really hard from gear to gear it also has a hesitate when you open throttle fast from low rpm
Answer
Replied on April 11, 2010
Clean out the idle air control valve/throttle plate and check acc. cable if its kinked and test the throttle position sensor and manifold absolute pressure sensor
