Engine overheating
JEDHEAD1985
  • 2002 LINCOLN LS
  • 165,000 MILES
My car keeps running hot, I recently changed the thermostat yesterday and it is running hot again today. It gets so hot that I can hear the water boiling inside of the coolant fill tank. It also leaks hot coolant and steam inside the car on the driver's side on the floor by the brake and acceleration pedals. It also leaks alot of water outside of the car on the drivers side. Can you please help me before I lose it?
Sunday, September 8th, 2013 AT 9:10 PM
CARADIODOC
  • 33,752 POSTS
It sounds like you have a coolant leak here is a guide that will walk you through the repair
https://www.2carpros.com/articles/car-is-leaking-coolant
Sunday, September 8th, 2013 AT 9:52 PM
JEDHEAD1985
  • 5 POSTS
Is the heater core expensive? Im on a tight budget at the moment. So a heater core will leak on the drivers side?
Sunday, September 8th, 2013 AT 10:09 PM
CARADIODOC
  • 33,752 POSTS
Actually, the heater core is on the passenger side. Coolant normally leaks into the drain pan for the water that condenses when the air conditioning system removes the humidity from the air, but it depends on how the system was designed. I suspect pressure in the cooling system is causing that hot coolant to spray over to the driver's side.
Heater cores are not outrageously expensive but the labor to replace them is. On most Ford products the steering column must be lowered and the dash must be pulled back to remove the heater box and actuators. The air conditioning hoses must be disconnected so that means recovering the refrigerant, then evacuating the system and recharging it. Thanks to your politicians and the EPA, air conditioning work is also expensive.
As a temporary measure you could disconnect the two heater hoses at the firewall, then buy a plastic fitting to connect them together. That will bypass the leak and it should stop the overheating. Keep in mind though that obviously you won't get hot air from the heater, but you won't get it from the defroster either. The air conditioner will still run in defrost most, like normal, to remove the humidity from the air so it won't condense on the cold windshield and cause fogging, but since the air will be cold, it will take longer to defog the windshield. If the other guy runs a red light and causes a crash, his lawyer and insurance investigator will look for things like that to try to shift some of the blame to you. That rarely happens, but I wouldn't be doing my job if I didn't at least mention it.
Monday, September 9th, 2013 AT 2:10 AM
JEDHEAD1985
  • 5 POSTS
Could I put the fitting on myself? And is the firewall easy to get to?
Monday, September 9th, 2013 AT 7:30 AM
JEDHEAD1985
  • 5 POSTS
Could it be the water pump?
Monday, September 9th, 2013 AT 8:30 AM
CARADIODOC
  • 33,752 POSTS
Sorry that I dropped the ball and failed to reply sooner. Have you solved the problem?
Sunday, January 19th, 2014 AT 7:22 AM
KEEPITGIGI
  • 2006 LINCOLN LS
  • 3.9L
  • V8
  • RWD
  • 194,507 MILES
I have replaced all aspects of cooling water pump, fan thermostat and reservoir still states hot after driving a short distance also have bleed system. Once it registers hot pull over turn off for ten to fifteen minutes then it is fine. What gives?
Thursday, June 1st, 2017 AT 3:15 PM (Merged)
KEN L
  • MASTER CERTIFIED MECHANIC
  • 42,959 POSTS
Is sounds like you may have a blown head gasket, please follow this guide to confirm
Please run this test and get back to us so we can continue helping you.
Cheers, Ken
GOOSE
  • 2001 LINCOLN LS
  • 75,356 MILES
My 2001 Lincoln overheats very quickly, I can see water boiling in the engine coolant compartment. The water from the compartment get so hot that it starts leaking from the top of the cap. The car also turns of after being in park for a couple of minutes and it also turns off when Im waiting at a stop light. Can you please help?
Check the thermostat and water pump operation if okay get it block and pressure tested
BIGBLOCKVP
  • 2002 LINCOLN LS
  • 6 CYL
  • RWD
  • 150,000 MILES
Car runs fine and operates normally without overheating until I turn on the A/C. If I disconnect the wiring plug on the compressor all is fine, but if reconnect it car immediately starts to overheat. Could the clutch be seized causing excessive load on the engine? What is the solution? Can I replace only the clutch to prevent having to recharge?
HMAC300
  • 48,601 POSTS
First see if your cooling fans are working on radiator. When you turn on A/C at least one should work. Then check fuses under hood fuse box there are relays there as well if fuse is good then check relays.
BIGBLOCKVP
Okay will do, but would the car overheat in hot summer temperatures if fans were not working? I have had this problem all last summer so I kept the compressor unplugged. I had no AC, but normal engine temperature at all times.
HMAC300
  • 48,601 POSTS
Normally there are two fans one comes on when A/C is turned on the other may have failed. If a mechanical fan the shroud around radiator is important as it will not direct air through radiator if not there. Also, it can be a radiator problem or something else but you need to start.
BIGBLOCKVP
Perfect. Will start there. Thanks!
KEN L
  • 42,959 POSTS
Cheers, Ken
THREES WILD
  • 2004 LINCOLN LS
  • 110,000 MILES
I have a 2004 Lincoln LS and I'm having the same problem as lemon cycle, the overheating and the fan not coming on. How do I find the fan senor attached to the engine? Then how to I check it to make sure it has malfunctioned?
The radiator housing has been replaced and so has the upper radiator hose. I took it in for code reading and it only gave throttle problems which may have been caused when I removed the clamp
  • 108,266 POSTS
Have you checked the relay and the sending unit?
THREES WILD
I'm not sure what those things are. I did check the 60 amp fuse and it was good, I then removed what I thought my be the fuse in the engine compartment by swapping with another fuse and that worked also.
KANDIDS
  • 2004 LINCOLN LS
Engine Cooling problem
2004 Lincoln LS V8 Automatic 75000 miles
My car is over heating so I took it in to a mechanic he said it was the heater control valve. I got that fixed and then my battery went dead, couldnt turn on the car after part was replaced. So I got a new battery and now my car is still overheating. It has a gurgling sound coming from the coolant reservoir. But there is plenty of coolant.
Got any ideas?
