Engine cranks but does not start
2005 ACURA RL
165,436 MILES
ZACKARZO
Bought the run and drive. I am guessing one the guys used a booster to start the car, after that day the car won't start at all.
You can hear it feels like it wants to start but then nothing
Work done on the car:
Replaced engine computer.
Reprogrammed the key more than once.
The guy at one shop told me some of the coils don't get spark.
Another guy told me it can be the anti theft.
Oh by the way, no codes on the Emc.
Love the car but can't get her started. any help?
Jun 17, 2013 at 9:00 PM
  • CAR REPAIR CONTRIBUTOR
Good evening,
Did you check for spark at the plugs?
Did or can you hear the fuel pump run when you turn on the key?
I would also check the compression to be sure the engine timing is correct.
Apr 10, 2020 at 5:45 PM
JUDSYK
Car won't start but turns over. Had it jump started. Drove to dealership and they said there is no electrical problem. (I had battery replaced 3 months ago, also battery in remote replaced 4 months ago).
Drove it next day and no problem.
2 days later, I drove to business. Came out 30 minutes later and car wouldn't start. Had it jump started. Drove it to dealership. They spent 3 hours checking it, tracing the electrical to see if maybe there was a loose wire. They can find nothing wrong.
Dealership says there are no recalls on the car. What is the problem? This car has never had any issues so I am confused. Would really appreciate your help.
Thanks.
Apr 11, 2020 at 4:13 PM (Merged)
KHLOW2008
  • 41,814 POSTS
Hi judsyk,
Does jump start work every time?
One of the most likely cause would be a bad battery. If your battery is the maintenance free type, it is known to intermittently fail and cause non starting.
JUDSYK
It was a new battery installed by the dealership about 3 or 4 months ago. The dealership has checked all electrical including the battery and says electrical is okay. The non-start problem started just one week ago.
Jump starting works every time very quickly but the non-start problem re-occurs after a day or 2.
A friend of mine with an Acura TL has a similar problem. He clicks the remote on and off several times and the car starts after that. I will have to try that when I get my car back from the dealership. But there must be a problem that can be fixed.
KHLOW2008
  • 41,814 POSTS
New batteries can also be defective and the best way to check the problem is to get a volt meter on standby and when you are not able to start, test the battery voltage.
When trying to start, does the starter seem to click but does not have sufficient power to crank?
If it is only quiet without any noise, then it could be a faulty ignition switch or starter relay.
JUDSYK
You're right, just not enough power to start. I had the dealership replace the battery even though it was new.
Thanks. Hope this works.
KHLOW2008
  • 41,814 POSTS
Good luck :)
Have a nice day.
JUDSYK
The battery was the problem.Thank you for your responses and insight. :)
